96 lx hard to start, and best place to buy factory parts
Hey guys,
The chicks 96 lx with 110k miles is hard to start when warm or cold. It takes many cranks for it to fire. The entire ignition looks great, plugs great, etc. Thanks for any ideas here.
In other news: need a timing belt/tensioner. Best place to buy factory parts online? Thanks!
Ian
Ian
Thought there might be an online place that sells factory parts for less... like most every other manufacturer our there...
Thanks for the options,
Ian
Ian
From: Land of the Hillbillies and Shotguns, Ontario, Canada
when my hondas almost emoty it does start harder. I have not done my fuel filter yet, it may be a slight cause.
A tune up should help your problems, check the cap androtor, check the plugs, also change wires
Yeah all that stuff is in good shape: I'm wondering if the fuel pumps go bad. Anyone?
It sounds like its dry cranking: spark is there.
THanks again for your help,
Ian
Ian
I've been having the same problem with my 97 LX periodically, and I think it's the fuel pump. I find if I turn the key to the "on" position and listen for the fuel pump to fully start up, and put my foot on the gas just a little, then turn it over the car starts just fine. Not sure how much longer the fuel pump can hold on like this, but I've been doing this for months now and the problem hasn't worsened any.
