Got a very crappy brake problem , how do I fix ?
Old Apr 8, 2007 | 01:30 PM
8_6 luder's Avatar
Default Got a very crappy brake problem , how do I fix ?
This has got to be one of the most annoying issues iv'e encountered yet . My rear brakes wont completly disengage. I can drive my car just fine other than the fact that my rear wheels arent free . Its caused me to loose my last two races , its killing my gas millage, and I simply cant stand that slight tug holding me back . Dose anyone know the cause and or the repair process thanks lots .
Old Apr 8, 2007 | 02:21 PM
fast_honda's Avatar
Default Re: Got a very crappy brake problem , how do I fix ? (8_6 luder)
do you abuse the e-brake?
Old Apr 8, 2007 | 02:38 PM
InvaderTrax's Avatar
Try disconnecting the ebrake at each caliper. If that fixes it, you either need to readjust your handle, or replace your cable
Old Apr 8, 2007 | 02:41 PM
PreludePhill's Avatar
i had a similar problem on my drivers side rear caliper.I have mine painted red and after a week i noticed that the painted turned really dark red/black and was flaking off.Turns out my caliper was siezing up.
Old Apr 8, 2007 | 02:51 PM
8_6 luder's Avatar
Thanks for your help I will try and see if that works. I figured it might have had something to do with air in the brake lines, so I bled it and to no avail.
Modified by 8_6 luder at 4:18 AM 4/9/2007
Old Apr 8, 2007 | 08:10 PM
TruNinja619's Avatar
try putting antiseize on the sliding pins of the calipers..
Old Apr 9, 2007 | 05:53 AM
prelude_h22vtec's Avatar
my sliders locked up...ruined a good pair of greenstuff. yea like they said, check the ebrake, if its not that, replace the calipers.
Old Apr 9, 2007 | 08:22 AM
copeman's Avatar
I may have the same problem, but it's really hard for me to tell. When I let off the gas my speed decreases really fast. I also see drastically different wear on all of my brake pads. BTW I only get like 20-22 mpg on a pretty good mix of hwy and city driving.
Old Apr 9, 2007 | 08:24 AM
SnlpeR's Avatar
ive had my sliders lock up too
easy fix
remove sliders from brake bracket....cleanup...regrease.. then reinstall
Old Apr 9, 2007 | 01:15 PM
8_6 luder's Avatar
Default Re: (SnlpeR)
I found the problem . Some how my pads wore unevenly . Whenever I used the brake, it pushed the low end of the pad to the roter . As I release the brake pressure completly the high end of the pad still touched the roter resulting in this problem. It was a big pain in the *** , i'm glad I figured it out. Now after all this time I can finaly see how fast my car realy is. lol
Old Apr 9, 2007 | 02:27 PM
bboixtc's Avatar
Default Re: (8_6 luder)
hmm, my brake problem is kinda weird. I have to push the brakes hard to slow down.. or come to a stop. Also as i am pressing the brakes to slow down, if it is raining, or when i go over bumps or holes, my brake pedal jerks weirdly. Anyone know the problem with my brakes by my desciption?
Old Apr 10, 2007 | 09:54 AM
8_6 luder's Avatar
Default Re: (bboixtc)
sounds like brake booster or master cylinder problems
Old Apr 10, 2007 | 09:59 AM
8_6 luder's Avatar
does anyone know how to push the caliper piston all the way in ? Im tring to change my pads but I cant get the damn piston all the way in for clearence .
Old Apr 10, 2007 | 10:49 AM
syntax.'s Avatar
the rear caliper pistons screw in. you need a wide screwdriver and turn them clockwise. if they still wont budge, they are seized and need to be rebuilt or replaced.
Old Apr 10, 2007 | 10:58 AM
bboixtc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8_6 luder &raquo;</TD></TR><TR><TD CLASS="quote">sounds like brake booster or master cylinder problems
me? or the other guy?
Old Apr 10, 2007 | 11:53 AM
godslayer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboixtc &raquo;</TD></TR><TR><TD CLASS="quote">
me? or the other guy?</TD></TR></TABLE>
You.
Old Apr 13, 2007 | 04:49 AM
Serenity Now!'s Avatar
Default Re: Got a very crappy brake problem , how do I fix ? (copeman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by copeman &raquo;</TD></TR><TR><TD CLASS="quote">I may have the same problem, but it's really hard for me to tell. When I let off the gas my speed decreases really fast. I also see drastically different wear on all of my brake pads. BTW I only get like 20-22 mpg on a pretty good mix of hwy and city driving.</TD></TR></TABLE>
i have the same problem- when i let off the gas, my car feels like its being held back, and not a steady deceleration (sp?). Any ideas?
Old May 17, 2007 | 02:15 PM
8_6 luder's Avatar
Default Re: Got a very crappy brake problem , how do I fix ? (thecanyon2k4)
You probley have the same problem as I did.
Old May 17, 2007 | 07:56 PM
m00nr0ck Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8_6 luder &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know how to push the caliper piston all the way in ? Im tring to change my pads but I cant get the damn piston all the way in for clearence .</TD></TR></TABLE>if you have tried to force the piston in without turning it you could have damaged the caliper ...There is a tool that helps in rotating them that you can buy at any parts store.
Daywalkin
May 30, 2010 10:39 AM
1sikcoupe
Feb 5, 2008 10:21 AM
dmiller33
Aug 11, 2005 02:07 AM
pmachan
Jun 7, 2004 05:39 AM
GorData
Dec 2, 2001 04:44 PM
