throttle valve dashpot and starting air valve what are they
what are throttle valve dashpot and starting air valve. i have them hooked up to a vacuum port on the manifold. but the car still idles at 4000rpm or so.
During engine cranking and after cranking if engine coolant temperature has not yet exceeded a minimum value, an air bypass valve (dashpot) provides maximum additional air to the engine fuel mixture in addition to the air provided in accordance with engine throttle position. During normal engine run conditions with the throttle not effectively closed, the dashpot provides minimum additional air to the fuel mixture. During deceleration when engine throttle is effectively closed, if engine speed is at least a maximum speed IDLEH and then declines, effective dashpot actuation will be 100% (maximum additional air) for engine speeds at least equal to IDLEH, 0% for engine speeds below a minimum speed IDLEL, and for engine speeds between IDLEH and IDLEL, the change (decrease) in dashpot actuation will be proportional to the change in current engine speed and substantially independent of time. If during deceleration engine speed decreases to IDLEL, then dashpot actuation remains at a minimum.
starting air valve
A system for controlling idle air flow for an engine. The system includes an idle air control valve, a stepper motor, and a controller. The idle air control valve has a first hard stop and a second hard stop. The stepper motor is coupled to the idle air control valve and configured to manipulate the position of the idle air control valve. The controller is in communication with the stepper motor to provide a driving signal. Further, the controller is configured to drive the idle air control valve to the first hard stop and then drive the idle air control valve to the second hard stop after receiving an engine shutdown command.
that_boy_sammy
Jan 13, 2013 02:58 AM
iNetForce
May 25, 2004 08:34 AM
