<<< How do u fix a crooked column...turnsignals & ignition?? >>>
Old Apr 8, 2007 | 12:41 PM
R-81DC2's Avatar
Default <<< How do u fix a crooked column...turnsignals & ignition?? >>>
Old Apr 8, 2007 | 12:44 PM
john666's Avatar
Default Re: <<< How do u fix a crooked column...turnsignals & ignition?? >>> (R-81DC2)
uhh,, remove the plastic where the column is and take a look,, worst comes to worse u could add a washer to one of the sides to even it out,, are you able to shake/wobble your wheel/column ?
quick add... are you sure the plastic around the column isnt just loose ??
Old Apr 8, 2007 | 01:04 PM
R-81DC2's Avatar
Default Re: <<< How do u fix a crooked column...turnsignals & ignition?? >>> (john666)
Old Apr 8, 2007 | 01:29 PM
dem0nk1d's Avatar
that's a damn good idea, washers... i should do that to my car. the steering wheel is a little off. and the wheels are in perfect alignment.
Old Apr 8, 2007 | 02:11 PM
R-81DC2's Avatar
Default Re: (dem0nk1d)
Old Apr 8, 2007 | 02:26 PM
john666's Avatar
Default Re: (R-81DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81DC2 &raquo;</TD></TR><TR><TD CLASS="quote">???????</TD></TR></TABLE>
whats your question or have i answered your question
Old Apr 8, 2007 | 02:36 PM
R-81DC2's Avatar
Default Re: (john666)
washers would only fix the plastic cover....the turnsignals would still sit crooked
Old Apr 8, 2007 | 02:38 PM
john666's Avatar
i guess i should explan everything more in detail... remove the plastic above where your knees would be,, i believe its 2 14mm nuts.. remove those and drop your steering column and add a washer to a side.. and would tilt everything to a side....
Old Apr 8, 2007 | 02:59 PM
dem0nk1d's Avatar
like i said darn good idea.
Old Apr 8, 2007 | 04:29 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81DC2 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
From this pic it looks like someone broke into your car. The column needs to be replaced.
Looks the same as when my car and my friend's car got stolen/broken into. We both needed new steering columns.
Old Apr 8, 2007 | 04:33 PM
93eg2james's Avatar
Default Re: <<< How do u fix a crooked column...turnsignals & ignition?? >>> (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
Looks the same as when my car and my friend's car got stolen/broken into. We both needed new steering columns.</TD></TR></TABLE>
Doubt it. When theives break into a car they dont take their time to unbolt stuff, they rip **** apart. If someone broke in the plastic cover would most likely be mangled.
Old Apr 8, 2007 | 05:06 PM
NOFX's Avatar
H-T White Ops
Default Re: <<< How do u fix a crooked column...turnsignals & ignition?? >>> (93eg2james)
I don't know if anything has been damaged and then repaired in the past for this car.
So I stand by it, it looks like it got broken into. I doubt he just got in one day and *poof* the steering column somehow bent itself.
Old Apr 8, 2007 | 07:09 PM
R-81DC2's Avatar
it was broken into before i got it and whatever got broke was replaced
Old Apr 8, 2007 | 07:11 PM
R-81DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">i guess i should explan everything more in detail... remove the plastic above where your knees would be,, i believe its 2 14mm nuts.. remove those and drop your steering column and add a washer to a side.. and would tilt everything to a side....</TD></TR></TABLE>
got it now but is there anyway to turn the whole column that the turnsignals and ignition are bolted on to
Old Apr 8, 2007 | 07:14 PM
R-81DC2's Avatar
there is nothing wrong with the steering at all nothing shakes or wobbles its just looks crooked
Old Apr 8, 2007 | 07:17 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81DC2 &raquo;</TD></TR><TR><TD CLASS="quote">it was broken into before i got it and whatever got broke was replaced</TD></TR></TABLE>
Okay then. You need to replace the column.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81DC2 &raquo;</TD></TR><TR><TD CLASS="quote">got it now but is there anyway to turn the whole column that the turnsignals and ignition are bolted on to</TD></TR></TABLE>
No, there is no way to twist the column back so that the turn signal and entire column is straight again. It isn't built that way.
If you want to fix it, you'll have to replace the entire column. Trust me. I've had this problem before. Steering was fine, everything worked (well, the ignition was messed up, but could have been replaced alone) but the entire thing sat crooked.
Old Apr 8, 2007 | 07:26 PM
R-81DC2's Avatar
If you want to fix it, you'll have to replace the entire column. Trust me. I've had this problem before. Steering was fine, everything worked (well, the ignition was messed up, but could have been replaced alone) but the entire thing sat crooked.</TD></TR></TABLE>
I understand but then again how could it be like that from theft???
Old Apr 8, 2007 | 07:28 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81DC2 &raquo;</TD></TR><TR><TD CLASS="quote">I understand but then again how could it be like that from theft???</TD></TR></TABLE>
That's what happens when they get stolen. I don't know if it happens ALL the time, but it happens a lot of the time. I don't know why, but I imagine it has to do with them breaking the steering wheel lock.
Here's my wheel after my car was stolen. Granted the steering wheel is turned a bit in this photo, but you can see the combo switch is also twisted to the side... which it shouldn't be.
Old Apr 8, 2007 | 07:34 PM
R-81DC2's Avatar
lmaoooo damn
thanks for your help
Old Apr 8, 2007 | 07:35 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81DC2 &raquo;</TD></TR><TR><TD CLASS="quote">lmaoooo damn
thanks for your help</TD></TR></TABLE>
Np. Good luck.
I'll give you a tip too. I got scammed when I bought my column. I was just excited to finally get a replacement and didn't think about that they gave me a new combo switch and such (I only needed the ignition and column that they gave me). So make sure they don't give you a new combo unless you want a backup (they're not cheap if one goes out). I had to pay for the extra combo switch they gave me. They also gave me the wrong column at first, but that's beside the point.
Old Apr 8, 2007 | 07:47 PM
DammitDan's Avatar
I got a 96-00 steering column with ignition and key. I bought for the same situation with my car, but it got stolen again before I can change it. Make me an offer.
Old Apr 8, 2007 | 07:52 PM
M0N0C4M's Avatar
Default Re: <<< How do u fix a crooked column...turnsignals & ignition?? >>> (DammitDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DammitDan &raquo;</TD></TR><TR><TD CLASS="quote">I got a 96-00 steering column with ignition and key. I bought for the same situation with my car, but it got stolen again before I can change it. Make me an offer.</TD></TR></TABLE> that just suks
Old Apr 8, 2007 | 07:57 PM
R-81DC2's Avatar
pm'ed
HATCHingMN's Avatar
I use spacers to fix mine crooked column, i think I use like 4-5 spacers.
It works but if you want a perfectly repair you have to replace the whole steering column.
Old Apr 8, 2007 | 07:58 PM
NOFX's Avatar
H-T White Ops
He'll need to get another steering wheel too then. 5th and 6th gen Civic steering columns don't have the same number of spines at the end, thus they take different steering wheels.
