Civic Trouble starting when cold
Old Apr 8, 2007 | 11:45 AM
DAVE15401's Avatar
Default Civic Trouble starting when cold
I have a 93 civic ex on monday tuesday and sunday when i went out and tried to start the car it wouldnt start and i checked the spark and was all good. after about 15 mins tring to get it to start it started to start but seemed like it was flooded then after about 3-4 mins it would start.Im thinking its the Idle Air Control valve am i right or what else could it be thanks ?
Old Apr 8, 2007 | 11:47 AM
fmrprojects's Avatar
Default Re: Civic Trouble starting when cold (DAVE15401)
check your battery voltage and your resistance across the power wire to the starter
Old Apr 8, 2007 | 11:48 AM
gezzuzz's Avatar
might be your coil.. how cold are we talking? im in new orleans i consider 50 cold
Old Apr 8, 2007 | 11:51 AM
DAVE15401's Avatar
Default Re: Civic Trouble starting when cold (gezzuzz)
its been about 30 and 40s but all winter i didnt have a problem it just started about a week ago and it was 5 below here in the winter .If it was the coil it wouldnt staRT AT all WOULDNT IT ?
Old Apr 8, 2007 | 05:40 PM
DAVE15401's Avatar
night bump
Old Apr 8, 2007 | 10:29 PM
gezzuzz's Avatar
i just had a coil that went bad.. and after i got it started it could be restart with no problem.. to test your coil do this.. when its cold take teh cap off.. the coil has 2 wires going to it.. + and - test the resistants between the wires.. it sould be between .6 and .8 ohm.. do you know how to do this?
Old Apr 9, 2007 | 04:16 AM
DAVE15401's Avatar
yea ill check this in about an hour but i just changed the coil in the dizzy
Old Apr 9, 2007 | 04:29 AM
4thgenx42's Avatar
Double check your battery.
Old Apr 9, 2007 | 04:49 AM
DAVE15401's Avatar
Default Re: (4thgenx42)
why double check the battery?
When i stopped at the store on way home last night i noticed my idle was moving from 800 to like 1800 rpm up and down making me more to believe the Idle Air Control valve.
Old Apr 9, 2007 | 02:52 PM
DAVE15401's Avatar
Default Re: (DAVE15401)
bump
Old Apr 11, 2007 | 04:17 AM
DAVE15401's Avatar
Old Apr 11, 2007 | 04:29 AM
93eg2james's Avatar
Maybe, But I'll put my money on the FITV (Fast Idle Thermo Valve).
Here's a link on how to clean yours
Old Apr 11, 2007 | 06:03 AM
JDMFantasy2k's Avatar
Default Re: (93eg2james)
just disconnect the hose to the FIV to rule out coil and battery issues. Your idle should skyrocket nicely, and if it doesn't then go from there.
dub204
Aug 20, 2006 09:14 AM
904d
Mar 23, 2005 09:41 PM
scrap1ngsr
Mar 29, 2003 08:26 PM
