whats this sensor or valve on b18a intake manifold
Old Apr 8, 2007 | 09:34 AM
komat's Avatar
Default whats this sensor or valve on b18a intake manifold
whats this thing on the b18a intake manifold circle red. i dont have it plugged in currently. im getting a extreme high idle at 4000rpm and it wont go down
Old Apr 8, 2007 | 10:06 AM
Luserkid's Avatar
Default Re: whats this sensor or valve on b18a intake manifold (komat)
EGR..... goes with the saying "if you dont know what its for its probably for smog"
Old Apr 8, 2007 | 10:11 AM
komat's Avatar
Default Re: whats this sensor or valve on b18a intake manifold (Luserkid)
i thought it was the egr but wasnt sure
im guessing im not suppose to have a vacuum line on that
would an automatic ecu on a manual setup cause the car to idle 4000rpm. only CEL im getting is the o2 which is not hooked up. i sprayed the whole intake manifold with carb cleaner but nothing happen
VTECinWOT
Oct 24, 2011 05:27 AM
.RTErnie
Welding / Fabrication
21
Sep 17, 2007 07:07 AM
RiversideS13
Jul 18, 2007 11:08 AM
Bitpicker1011
Nov 16, 2004 12:30 PM
