coverting your hard brake lines to stainless steel braid lines...
Old Apr 8, 2007 | 08:09 AM
.BigSexy's Avatar
most hood white kid
Default coverting your hard brake lines to stainless steel braid lines...
Ok, so while my engine is out, I am wanting to do this. I am also wanting to mount my proporion valve somewhere other than on the side of the frame/engine bay.
will I have to worry about the the lines expanding? b/c I know brake fluid expands when it gets hot. Will I have anything to worry about?
Old Apr 8, 2007 | 01:52 PM
.BigSexy's Avatar
most hood white kid
Default Re: coverting your hard brake lines to stainless steel braid lines... (egcoupe94)
anyone experienced this?
Old Apr 8, 2007 | 04:44 PM
Speedra500's Avatar
why do you want to do this?
Old Apr 8, 2007 | 04:47 PM
.BigSexy's Avatar
most hood white kid
Default Re: coverting your hard brake lines to stainless steel braid lines... (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">why do you want to do this?</TD></TR></TABLE>
to move the prop valve to the firewall. no real gain except a cleaner look. i wonder if i could just use civic hard lines?
Old Apr 8, 2007 | 05:26 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">
to move the prop valve to the firewall. no real gain except a cleaner look. i wonder if i could just use civic hard lines?</TD></TR></TABLE>
I would use as many hard lines as you can. You can get some pre-made straight lines from the auto parts store and they're not that hard to bend if you get a tubing bender...I just think that several yards of SS line would flex too much plus it's pretty expensive.
Old Apr 8, 2007 | 05:30 PM
.BigSexy's Avatar
most hood white kid
Default Re: coverting your hard brake lines to stainless steel braid lines... (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
I would use as many hard lines as you can. You can get some pre-made straight lines from the auto parts store and they're not that hard to bend if you get a tubing bender...I just think that several yards of SS line would flex too much plus it's pretty expensive.</TD></TR></TABLE>
true...but what about mounting the lines to the firewall, that way there would be less flex...
Old Apr 8, 2007 | 05:31 PM
Hawkze_2.3's Avatar
true...but what about mounting the lines to the firewall, that way there would be less flex...</TD></TR></TABLE>
How? They're still the same lines...
Old Apr 8, 2007 | 05:35 PM
.BigSexy's Avatar
most hood white kid
How? They're still the same lines...</TD></TR></TABLE>
so ur talking about expanding right? i was talking about if they werent mounted, the fluid going through them would cause them to move...
i guess its hard to explain what im talking about...ill just stick with my hardlines
Old Apr 8, 2007 | 05:38 PM
Hawkze_2.3's Avatar
Yeah, I meant expanding and making the pedal more and more mushy. I think it would be a lot of trouble for you with no real performance benefit (probably a loss) and it would be expensive.
Old Apr 8, 2007 | 05:42 PM
.BigSexy's Avatar
most hood white kid
Yeah, I meant expanding and making the pedal more and more mushy. I think it would be a lot of trouble for you with no real performance benefit (probably a loss) and it would be expensive.</TD></TR></TABLE>
true...was just trying to think of a way to clean the bay a little bit more...
u got pm..
LilCivic04
Welding / Fabrication
37
Jun 22, 2007 10:06 AM
null.
Jun 8, 2007 10:27 PM
o2flow.net
Sep 27, 2006 11:23 AM
Pandahatch
36
Feb 17, 2006 01:13 PM
StatGSR
Apr 28, 2005 12:55 PM
