Vacuum hose on intake manifold
Old Apr 8, 2007 | 02:34 AM
jumai182's Avatar
Default Vacuum hose on intake manifold
I running a swapped b16a2 in a ek hatch. On the stock intake manifold there is a vacuum line on the opposite side of the TB towards the bottom. I dont have a hose connected there but when I plug it, drops the idle from 1500-2000 down to 800. What is it and where is it supposed to plug into? Is it the cruise control vacuum?
Old Apr 8, 2007 | 02:47 AM
Luserkid's Avatar
Default Re: Vacuum hose on intake manifold (jumai182)
Sounds like the cruise control nipple. If theres nothing attached to it its called a vacuum leak. Cap it.
Old Apr 8, 2007 | 02:51 AM
jumai182's Avatar
Default Re: Vacuum hose on intake manifold (Luserkid)
Yeah I know its leaking, my car idles pretty high. That might be what it is, what does it connect to and whats normally plugged into it?
Old Apr 8, 2007 | 03:01 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the cruise control nipple. </TD></TR></TABLE>
Old Apr 8, 2007 | 11:01 AM
jumai182's Avatar
where does it connect to? I dont have a hose there at all.
Old Apr 8, 2007 | 11:11 AM
Pr0ject93hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jumai182 &raquo;</TD></TR><TR><TD CLASS="quote">where does it connect to? I dont have a hose there at all.</TD></TR></TABLE>
they told you is a cruise control line...ims ure you dont have cruise control on your swap. so just cap it off. if you have cruise control then you have to find where it goes.
Old Apr 8, 2007 | 06:48 PM
jumai182's Avatar
Default Re: Vacuum hose on intake manifold (Pr0ject93hb)
What would I cap it off with? Sorry Im not too familiar with this and I would like to do it right, no halfassing it.
Old Apr 8, 2007 | 07:51 PM
jmsp EG'zer's Avatar
there are lil rubber caps i used to cap mine. just go to your local parts store and ask them for vacuum port plugs or something. until you do that look for a hose that will fit snug around the nipple and block it off with a bolt at the other end. vacuum leaks are bad.... so fix it fast
Old Apr 8, 2007 | 09:43 PM
jumai182's Avatar
Default Re: (juggernaut_eg5)
I see, thanks alot.
5exy_Ek
18
Oct 26, 2010 04:56 PM
jmccalip
Jun 15, 2008 09:45 PM
CSHornet60
Mar 9, 2007 06:00 PM
drumminforev
Mar 11, 2006 12:42 PM
