How to remove pistons/rods?
trick to main caps is a rubber mallet, you want the piston that is being removed at bdc, then work the main back and forth then hit the rod directley to get the piston out of the way and rotzate to the next cap
what you are prolly doing is having the main being pulled or yannked by the crank, eaisest spot to remove by far is bdc, it is fine to rotate with less than 4 pistons locked in
what do u mean seized, hydro locked or just stuck, ivegotten motors out the same way that were rusted thick, just work on it and kep going, upgrade to wood and a metal hamer if its not working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports »</TD></TR><TR><TD CLASS="quote">what do u mean seized, hydro locked or just stuck, ivegotten motors out the same way that were rusted thick, just work on it and kep going, upgrade to wood and a metal hamer if its not working </TD></TR></TABLE>
nvm i got it out. crank spins all the way now, but still cant get the damn crank pulley nut off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports »</TD></TR><TR><TD CLASS="quote">its a bolt use air </TD></TR></TABLE>
opps yeah sorry. already tried using an impact.
jolt-tsp
10
Jun 10, 2005 09:46 AM
