03 Accord cruise control
My cruise control on my 03 Accord 4 cyl stopped working recently. The cruise light works, but when I hit the 'set' button the light will come on, but when released, the light will turn off again. And the cruise never engages. I've tried locating the fuse for it in the fuse boxes but could not identify which was designated for cruise control. Any help out there?
Thanks in advanced
Thanks in advanced
Does the horn work? There are two fuses. #13 (15A) in under hood fuse relay box. # 18 (15A) in under dash fuse box. Could also be brake pedal position switch, or clutch pedal position switch (M/T). Check the fuses and horn operation, and reply with results. Good luck
BJM3x96813
Jul 28, 2014 09:01 AM
