HELP: autometer gauge wiring?
I have an autometer #4353 full sweep 0-100psi oil pres gauge with a 3 wire sender. the gauge has a 10 pin clip on the back of it, and when it was removed from the previous vehicle, a black wire fell out of the clip. if someone has a pic of the back of the gauge with the clip installed that would be great. i already searched autometers tech/install section, and it dosent show jack. thanks alot
http://www.autometer.com/productPDF/0621B.pdf
if you look at the bottom of these directions, it shows a 10 pin connector. i need to kno,
positive
ground
sensor +
sensor -
sensor sig
Modified by JDM1civic at 8:35 PM 4/7/2007
positive
ground
sensor +
sensor -
sensor sig
