Suspension & Brakes Theory, alignment, spring rates....
Would I need a camber kit?
Old Apr 7, 2007 | 04:03 PM
Civic2000EX's Avatar
Default Would I need a camber kit?
My 2000 Civic EX is lowered on tein s tech springs with dropzone struts. I've been thinking about taking it in for an alignment, since I haven't done it since I've dropped the car. But I'm not sure if I'd need a camber kit. What I don't want to do is take it to get it aligned, pay for the alignment, and then be told that I need a camber kit and then need to pay for another alignment after installing the camber kit. So my question is, will a camber kit be necessary? The drop is only about 2 inches all around.
Old Apr 7, 2007 | 05:18 PM
t0p_sh0tta's Avatar
Default Re: Would I need a camber kit? (Civic2000EX)
You need an alignment to set the toe, so your tires don't go bad before your next oil change.
If you go without a camber kit, they'll tell you that you need one.
Did you just answer your own question?
Old Apr 7, 2007 | 08:20 PM
Thanks for your help. So what camber kit would you recommend?
Old Apr 10, 2007 | 10:05 AM
Has anyone tried the blox racing front & rear camber kits? I can get a pretty good deal for them, but I wanted to know if it would be worth getting. I'm not too familiar with that brand.
Old Apr 10, 2007 | 11:06 AM
nonsense's Avatar
Default Re: (Civic2000EX)
Just get the toe set as close to zero as they can front and rear and don't worry about the camber kits. If you want less rear camber use some washers to shim out the rear UCA before you get an alignment. If they try to sell you a camber kit say no thanks, if they will only do an alignment with a camber kit installed go somewhere else.
FLACO EM1
Nov 27, 2008 01:39 PM
donger
Jan 30, 2006 01:10 PM
TegoDC5
15
Oct 20, 2004 10:01 AM
babes 99 GSR
Sep 25, 2003 10:29 AM
MikeyDB7
Mar 13, 2003 03:22 PM
