F22b1 block, with headswap: what oil ports do I plug on the block?
Sup guys, im going to swap a f20A dohc head that I have here since I hear the B1 head doesnt flow as well. What oil ports do I plug on the block? What should I use to plug them? Any advise or links would be appreciated.
thanks guys
thanks guys
Use Hondabond to plug any oil passages.
Use the headgasket that corresponds with the new head to check which oil passages need to be plugged.
That's what most of done. The Accord FAQ has links in the "swap" section for other head swaps. You can check those out to get a better idea of what you'll be up against.
I think what philadd meant about checking the Accord FAQ was to see how others have plugged the oil passages, not on how to do the swap exactly.
Corksil
Apr 29, 2011 11:15 PM
