B16 header for 89 hatch?
What header will work for a 89 hatch with a b16 in it. I see people with headers but the dont say what kind they are. Please help me with part #'s and where to get these headers at. Thanks
Well, for headers you buy for the motor in this case.
So a 99-00 SI header will work, now it might require a bit of fabing and probbly a cut knuckle or two as it's a tight squeeze.
It says your from Newark DE, it's odd you guys call it newerk while the Newerk in NJ is said like nork.
Yeah i heard that a 92-95 del sol header would work but u have to flip the flange and I heard a gsr header would fit just right no fab needed but what year gsr header would I need. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic89stdB16 »</TD></TR><TR><TD CLASS="quote">Yeah i heard that a 92-95 del sol header would work but u have to flip the flange and I heard a gsr header would fit just right no fab needed but what year gsr header would I need. Thanks</TD></TR></TABLE>
It would need to be for a del sol vtec, or you'll end up with a D series header, you can use any GSR header if you want but it'll be a bit taller/longer.
a 99-00 si will work with less hassel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper »</TD></TR><TR><TD CLASS="quote">
? the gsr's are shorter not longer, a ls header will fit as well, but if you are obdo you will have to weld new bungs on up front for the o2's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">
? the gsr's are shorter not longer, a ls header will fit as well, but if you are obdo you will have to weld new bungs on up front for the o2's. </TD></TR></TABLE>
it's a taller block?
i've been drinking booze worth more then my car so you might be right, gsr blocks are taller though...
i'm lost.
i'm lost.
Lucky-13
Feb 12, 2007 10:21 AM
biglebowskicivic
Oct 27, 2003 07:53 PM
