Have anyone seen such water leak on H series engine?
Old Apr 7, 2007 | 08:19 AM
Root79's Avatar
Default Have anyone seen such water leak on H series engine?
This is second engine in last 2 years which have water leak directly from engine block wall. Seems like out of nowhere. Under factory marks.
Something around ~500ml of coolant on 6 miles engine losing.
Have video too, don't know where to upload.
Old Apr 7, 2007 | 09:25 AM
deucedeuceEK's Avatar
Default Re: Have anyone seen such water leak on H series engine? (Root79)
wow, thats crazy. I've never heard of anything like that before. I guess if my h starts doin that, I wont be shocked now
Old Apr 7, 2007 | 10:42 AM
arc_55's Avatar
yea i have never seen anything do that before! Fill the cooling system and pressure test the system and watch to see if you actually have a crack in the engine block.
Old Apr 7, 2007 | 01:01 PM
Root79's Avatar
Default Re: (arc_55)
video:
http://videos.streetfire.net/v...e.htm
Modified by Root79 at 12:37 AM 4/8/2007
Old Apr 7, 2007 | 02:09 PM
shauniewalnuts's Avatar
Default Re: (Root79)
i dunno.... im thinking the headgasket
Old Apr 7, 2007 | 02:52 PM
SlowReaction's Avatar
Default Re: (shauniewalnuts)
Take of the header and take look.
Old Apr 7, 2007 | 05:23 PM
arc_55's Avatar
there is no frost plugs on the front or blockoffs going into the block in that area? I have never worked on an h22 so i don't know.
Old Apr 7, 2007 | 05:38 PM
slo blue's Avatar
i have seen a few h motors leak there. we always just weld the hairline crack.
Old Apr 8, 2007 | 02:01 AM
Root79's Avatar
Default Re: (slo blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo blue &raquo;</TD></TR><TR><TD CLASS="quote">i have seen a few motors leak there. we always just weld the hairline crack.</TD></TR></TABLE>
I'm not English speaking man, could you explain "hairline crack".
I'm shop owner, this is costumer car. Have some H series blocks lay around, that's not the problem, to change it.
We just did dyno tune, install intake and did some job to exhaust. Car finally start to run very well. Sad to see such things after successful tune. As it is not first time, would like to know, maybe this could be H series sickness/problem!
Old Apr 8, 2007 | 05:53 AM
slo blue's Avatar
the hair line crack is a fine crack about the thickness of a hair. it is caused by poor casting when the block is made. after prolong heat and age the casting flaw becomes a crack.
Old Apr 8, 2007 | 07:23 AM
Root79's Avatar
Engine is from 1994 year 4 gen lude. Costumer install this engine by him self. As I understand this the donor car was not moving for about 3 years, maybe this long time standing could cause the block. Because we tune it at WOT for some hours.
I have some engines and there will be no any risk if he weld this hair line crack.
I don't have ac/dc welder only for stainless. So, the car owner will do the welding somewhere else. I recommend to drain the water, oil and carefully clean the crack. I will update this trouble next week after Easter.
Maybe you have some pics?
luvs2h8
Honda CR-V & Element
Nov 6, 2013 03:48 PM
Axle
Dec 5, 2006 03:43 PM
kenzieambrose
May 27, 2005 05:31 PM
SkylineGTR
Feb 5, 2004 04:45 PM
