fuse box remover
i have a 92 honda prelude S and i was wondering how mant screws and how do u take off the fuse box under the dash? its becuase my right front side marker does not work its does not work at all ive trace it back to all the connections and all the fuses and light bulb are good. does anyone have any suggestions on what could b the problem? im only getting like .498 voltage to the light bulb also the weird part is when i turn my signal to the right the turb signal does not flash really fast as it should when both lights are not working... thanks again prelude lovers
integrated control unit - i think this is probably your problem, but be sure to check for shorts in the turn signal and hazard systems as they can fry the box. its located on the back side of the underdash fuse box.
it plugs right in the back of the fuse box. along with the side marker circuts it also controls a number of other circuts. the fuse box has (3) 10mm bolts holding it in if i can remember correctly, the upper 2 bolts can be a bitch to get to no matter what exntensions and universal joints you use unless you take off the dash so good luck getting to them.
GeorgeJetson
Feb 19, 2004 10:43 AM
