bench bleed MC if lines are dry?g
Old Apr 7, 2007 | 05:41 AM
steronz's Avatar
Default bench bleed MC if lines are dry?
Do I need to bench bleed my new master cylinder if all the brake lines are dry? I haven't found any evidence to confirm this, but my guess is that the point of bench bleeding is to save the PITA of pushing all the old fluid out of the lines just to get the air in the MC out. Figure since I need to do that anyway, starting with a bled MC won't really save me much time, and just adds an extra step.
Old Apr 7, 2007 | 06:07 AM
hondamanwill's Avatar
yes if not you will be bleeding the whole system a bunch of times. Make shure when you bench bleed do not bottom out master may cause the seal to get cut.
Old Apr 7, 2007 | 10:22 AM
arc_55's Avatar
yes i would bench bleed it and then gravity bleed the system once the master is in place. Once it is completely gravity blead i would then pressure bleed the system to ensure no air is in the system and you don;t have any brake fade.
regnevazota
Jul 5, 2015 11:00 AM
Hondatuner88
Jan 30, 2008 08:50 AM
Greg123
Mar 3, 2007 05:11 PM
bOOsTiNSoHcVtEc
May 27, 2004 12:58 PM
Volcom
Mar 16, 2002 09:04 AM
