CRX trunk crooked?, help me out here..
Old Apr 7, 2007 | 05:06 AM
Contender25
Guest
Posts: n/a
Default CRX trunk crooked?, help me out here..
My trunk on my crx is not the original, everything else is on the car, well anyways it's off by like about almost a inch, maybe bout a half or so. The end of the trunk sticks out farther then the sides is what im sayin.
Im not sure as to whether or not take the trunk off and adjust the latches on both sides, or to loosin them and try pushing on it a little to budge it back a little?.
Old Apr 7, 2007 | 05:10 AM
Contender25
Guest
Posts: n/a
Here is a photo as to how off it is, the red line shows how far out it is.
Old Apr 7, 2007 | 05:16 AM
D Rex's Avatar
Default Re: CRX trunk crooked?, help me out here.. (Contender25)
Loosen the bolts on the hinges (at the roof) and adjust as needed. Have a buddy help, hatches are heavy. Then adjust the latch. It takes quite a while to get them to line up just right. I assume you have the right hatch.
Good luck
Old Apr 7, 2007 | 05:20 AM
Contender25
Guest
Posts: n/a
Well there are bolts under the roof linear that hold the trunk on, then there are two 10mm's at the latches that hold the trunk onto the latches.
So your saying the 10mm's right?, on the latch itself, not actually take the latch off just loosin them right?. I was gonna try that first but how do you take off the panel piece covering them up, i got this chrome looking tab across it and i don't wanna break it.
Old Apr 7, 2007 | 05:21 AM
Contender25
Guest
Posts: n/a
I don't know what the other CRX trunk came off of, but i thought they were all the same in size and dimension, lol?.
Old Apr 7, 2007 | 05:40 AM
harmonator84's Avatar
Default Re: (Contender25)
Kinda hard to tell by the pictures. I mean it actually looks straight in that pic. But anyways, yea just loosen the bolts up top..dont take them out just loosen them. Then push/pull the hatch were you want it and tighten the bolts back up. Good luck.
Old Apr 7, 2007 | 05:50 AM
Contender25
Guest
Posts: n/a
Well thats not my crx, i used that photo to describe what im tryin to say, the red line is how far out my trunk is from the sides.
Old Apr 7, 2007 | 06:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 &raquo;</TD></TR><TR><TD CLASS="quote">Well thats not my crx, i used that photo to describe what im tryin to say, the red line is how far out my trunk is from the sides.</TD></TR></TABLE>
Ohhh makes since now.
Old Apr 7, 2007 | 03:21 PM
Contender25
Guest
Posts: n/a
meh i fixed it, straight now.
streetsold6teeny8
12
May 19, 2009 05:12 PM
slow91crxdx
May 24, 2008 03:14 AM
bumthology
May 11, 2006 01:41 PM
Robster Craw
18
Feb 1, 2005 05:25 PM
iluvsleepers
Mar 6, 2004 01:55 PM
