Brake Kit
Old Apr 6, 2007 | 10:18 PM
anhthanh's Avatar
Default Brake Kit
planning to change my rotors, calipers and pads , mine looks all worn out. wondering how much would stock be or i should put out taht extra buck for a better one. was looking at the POWER SLOT PLUS BRAKE KIT sounds better then OEM brake kit.. wanted the brembo one but dams its expensive 2 G's plus.... any advice wat i should do thanks
Old Apr 7, 2007 | 07:21 AM
GraphiteMW's Avatar
Default Re: Brake Kit (anhthanh)
First, you don't need to change your caplier.. Just change your pads and rotors then you'll be fine.
If your looking for a OE replacement get some brembo blanks and axxis pads
Old Apr 7, 2007 | 07:58 AM
InvaderTrax's Avatar
My Hawk HPS pads aren't that impressive. Better than OE, but still not as good as my old EBC RedStuff
Old Apr 7, 2007 | 10:46 AM
tarheelsoldier's Avatar
Default Re: (InvaderTrax)
if ur wanting to do a complete change. go to Advance Auto parts. you can order the Acura NSX or Acura Legend twin piston calipers. and get 4g Vtec rotors or the legend rotors depending on 4 or 5 lug. the NSX calipers are ~$200 each with core charge included. and the rotors are roughly $50-100 a piece. otherwise... pads use EBC as above
Old Apr 7, 2007 | 05:20 PM
anhthanh's Avatar
thanks for the help guys
dragonkx
13
Jun 29, 2010 07:37 AM
b18c5 power
Jul 1, 2009 10:04 PM
evosix
Suspension & Brakes
17
Dec 23, 2008 12:22 PM
standbackimapro
Sep 21, 2007 11:27 AM
ITR #0202
Nov 17, 2002 08:50 AM
