cam advice
Old Apr 6, 2007 | 07:00 PM
no_sir's Avatar
Default cam advice
https://honda-tech.com/zerothread?id=1945819
Old Apr 6, 2007 | 07:20 PM
tony413's Avatar
they should be ok get cam gears the best thing for SC engines is letting the exhaust breathe as free as possible the SC will take care of the intake side as for overlap i havent dealt with SC's in imports to answer directly ask me for domestic an i can tell you
Old Apr 6, 2007 | 08:52 PM
no_sir's Avatar
Default Re: (tony413)
thanks .. i have adjustable cam gears and 70mm tb i just didnt list everything .
Old Apr 6, 2007 | 09:06 PM
tony413's Avatar
Default Re: (no_sir)
np what you looking to get out of the SC
Old Apr 6, 2007 | 09:12 PM
no_sir's Avatar
not quite sure of the full power ... on 10lbs maybe 275- 300 ish ..i just dont want to loose power or blow the motor by using the incorrect cams
Old Apr 6, 2007 | 09:14 PM
tony413's Avatar
come to think of it i've never seen a SC blow a motor.... on a street car anyway but sounds good keep me posted on the build
Old Apr 6, 2007 | 09:17 PM
no_sir's Avatar
ok ..should have it running in a week (fingers crossed )
Old Apr 7, 2007 | 05:25 AM
rmcdaniels's Avatar
Default Re: cam advice (no_sir)
You'd be better off selling the Stage3"s and getting a GSR intake with an ITR exhaust.
I tried some NA cams on my SC setup with less duration than the Crower Stage3's, and lost a lot of power compared a $50 set of GSR cams that we swapped onto the motor on the dyno.
SC's don't like too much overlap, they are limited in what they can flow and get real inefficient if you have too much overlap in your cams.
The Crower Stage 2 Forced induction cams look interesting, about the duration of the GSR-I/ITR-E combo, but with more lift. I got a set for my SC motor and made 275 WHP on 6.5 PSI from a JRSC and that motor was trashed (up to 40% leakdown past the rings and a bad head gasket). The motor's apart getting some new pistons now, but I should have it together again in a frew weeks.
Old Apr 7, 2007 | 10:37 PM
no_sir's Avatar
Default Re: cam advice (rmcdaniels)
so you think the crower stage 2 turbo cams are the way to go ? thanks
Old Apr 7, 2007 | 10:38 PM
no_sir's Avatar
Old Apr 7, 2007 | 11:27 PM
rmcdaniels's Avatar
I wouldn't say they were the way to go, but they look interesting. I think the GSR intake and ITR exhaust is probably the best proven combination for a JRSC setup.
Old Apr 8, 2007 | 04:24 AM
Joseph Davis's Avatar
Hey, since you've had every possible Honduh configuration under the sun and then a few that aren't, what is your experience with dialling the intake cam forward, like on the K-series? That's where the power is on those cars unless you choke off the exhaust.
Old Apr 8, 2007 | 10:28 AM
rmcdaniels's Avatar
Default Re: cam advice (Joseph Davis)
It depends on the setup and the cams, I've gotten some really good results from about 4 degrees of extra separation with B16 cams on supercharged setups, they really don't like too much overlap, but I'd think that it would be the opposite on a N/A K-motor, so some intake advance should net you some gains. On my turbo setups it never made a significant difference from the stock settings, so I always just ran them stock. It seems like every setup is different though, so I'll degree the cams to see what I can get away with without the valves hitting the pistons or each other and adjust them on the dyno to see what happens.
Old Apr 8, 2007 | 02:24 PM
no_sir's Avatar
what would you say i go with then ? i have the jdm b16a cams that came with the motor or crower stage 3 n/a .. or option 2 buy something new ? thanks for all the feed back
Old Apr 8, 2007 | 07:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">On my turbo setups it never made a significant difference from the stock settings, so I always just ran them stock.</TD></TR></TABLE>
Yah, K-series are the same way in that respect, and I suppose a lot of other engines are as well. Pushing past the 300 whp range - which is not remotely fast in 3000 lb pig carts like EP3 or DC5 - the fuel and ignition maps for the various cam angles start looking increasingly different while the power curves look increasingly similar. At the 500+ level with everything tuned there is a barely a difference in power curves.
Give me a D or a B in a CRX any day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no_sir &raquo;</TD></TR><TR><TD CLASS="quote">what would you say i go with then ?
You were already given solid advice, you need to stop dicking around and follow it. All you are going to get at this point is either a bunch of people agreeing with rmcdaniels, or a bunch of fools with 16-18 second Accord automatics demonstrating how stupid they are.
vtecmasta85
29
Sep 16, 2013 02:16 PM
Earthworm Jim
Oct 21, 2010 02:15 AM
DOHCon15s
May 12, 2003 01:36 PM
Death_to_Thieves
Dec 5, 2002 09:51 PM
Death_to_Thieves
Dec 5, 2002 11:00 AM
