EG6 Civic 92-95 horn won’t work; aftermarket wheel
I have a civic 92 hatchback and about a year ago I installed an aftermarket steering wheel along with the hub and quick release. I recently purchased NRG quick release, hub, and I changed my steering wheel to a MOMO tuner. When I installed my first aftermarket steering wheel I didn’t bother to put the horn to use because I knew I was going to buy me a NRG, it was only going to be temporary, but now a year later I don’t remember if I took out something that made the horn work. Is there a copper or something that is in between the short hub and the steering column? I know that the EF8 had a little copper piece. does the EG6 come with it too?
You should start here, and modify it to work with your NRG setup
https://honda-tech.com/zerothread?id=273474
95egianp
Oct 25, 2012 07:18 AM
bong_671
Feb 25, 2006 06:34 AM
