building b16a N/A set up, camshaft questions..
i have b16a(usdm) and i m looking at
b18 Type R Intake Camshaft, GSR Exhaust Camshaft...
what's the pros and cons of mix matching these two cams in b16a..?
r they worth it to swap..?
thank you so much..
thank you so much..
personally if your going all motor gsr cams will not make much of a diff from b16. i would swap for ctr cams both intake and exhaust. ctr are a lil more agressive than the older itr but the new itr years are ctr cams. ctr are the most agressive b series cams made by honda.
Depending on what your HP goals are. Under 350ish hp...I would go with GSR/ITR/CTR
If you're looking for big HP numbers I would look into Crower/Skunk/etc
Stage 2 or 3 - Once again depending on your HP.
