Rate my welds V.1 from myself...
A lot of them do, but I know how a camera can play tricks with the shadowing. Also looks inconstant, like your not moving the torch evenly around the pipe.
jeebers, i need more practice. I have made a handful of manifolds and so far (knock on wood) none have cracked or had any issues though
Top mounts or rams have a lot more room to expand, and more runners to take stress upon. Log manifolds see the most amount of stress. How many passes are you doing ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">Top mounts or rams have a lot more room to expand, and more runners to take stress upon. Log manifolds see the most amount of stress. How many passes are you doing ?
</TD></TR></TABLE> yea, i figured that.
Yea pig, i have the shakes, i have to reset alot, but its all in learning
So far, i am getting by and getting better. No returns to date yet
Thanks man!
Thanks man!
forgot to add: When i weld, i usually just lay the filler in the bevel and run the torch in a weaving pattern over the filler. I slightly push the filler into the puddle to get more filler in the weld. Hence why the beads are in a weaving (side to side) pattern. Engloid told me to try it a few weeks ago, so i am trying to get it down instead of just dabbing it like most do. Just playing with all the alternatives to see what i like and dis like
Instead of laying the pipe flat so you are starting on a vertical up and ending kind of flat try standing it up on end. you know like a boner. then weld around it. It's easier to twist around it that way. With a little practice you will be able to weld upside down horizantally while hanging from your toes
I did that once. It was awsome until I passed out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ManBearPig4silly »</TD></TR><TR><TD CLASS="quote">Instead of laying the pipe flat so you are starting on a vertical up and ending kind of flat try standing it up on end. you know like a boner. then weld around it. It's easier to twist around it that way. With a little practice you will be able to weld upside down horizantally while hanging from your toes
I did that once. It was awsome until I passed out. </TD></TR></TABLE>
Its best when you pass out and the hot filler drips on your eye lids.
HAHAH. I love you name too, its odd.
I usually weld the horizontal way, so yea... i am going to go out in the 33degree garage and try that out here in a few.
have you tried to weld while at your bench getting a BJ? thats interesting too.
Yes that is the way to go. It looks as though when you get near the end of the weld your torch angle is very extreme possibly causing your filler to ball up a little? it's almost impossible to be consistant when that happens. turning down the amps and using a bigger filler rod can help also. It's almost easier to pull the filler OUT of the puddle just a wee bit than it is to force it in consistantly.
Its best when you pass out and the hot filler drips on your eye lids.</TD></TR></TABLE>
Naw I was migging inside a huge steel box. some jackass decided it would be sweet to add some bracing...from the inside....after the box was welded.
Genius.
Genius.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">yea, that does happen at times, how do you spot that anyways! jesus!
I've personally made like every welding mistake known to man
</TD></TR></TABLE>I've personally made like every welding mistake known to man
</TD></TR></TABLE>nothing to be ashamed of, its all in learning. Hell least we can weld, alot of people can NEVER get it down or even understand the basic principles of it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">didnt know that was possible, hahahah
Yeah contamination is possible.
</TD></TR></TABLE>Yeah contamination is possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">you sell that turbo yet!!</TD></TR></TABLE>
waiting for you buddy
