Where to go to get a Suspension job in San Jose
Old Apr 6, 2007 | 01:10 PM
Nicks95GSR's Avatar
Default SUSPENSION!!!! NEED HELP!!!!
Im thinking of getting a suspension job for my 95 integra. What brand do u guys reccomend, I want something descent with a good price. Want to spend no more than $800. What else do i need to buy for the suspension? I know I need to buy shocks, and thats pretty much it. If you could please help me out on this one, that would be koo!
Thanks HT members
Modified by Nicks95GSR at 10:26 PM 4/12/2007
Old Apr 6, 2007 | 01:30 PM
Rahxephon's Avatar
Default Re: Where to go to get a Suspension job in San Jose (Nicks95GSR)
ground control and koni yello end of story.....
Old Apr 6, 2007 | 01:36 PM
numbnuts22715's Avatar
Default Re: Where to go to get a Suspension job in San Jose (Rahxephon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rahxephon &raquo;</TD></TR><TR><TD CLASS="quote">ground control and koni yello end of story..... </TD></TR></TABLE>
true story..
Ground control coilovers, and koni yellow shocks.
Old Apr 6, 2007 | 01:41 PM
Tornadom's Avatar
I can't lie... the 2 people posting above me are right.
Koni Sports (Yellows) + Ground Control coilovers.
Old Apr 6, 2007 | 02:43 PM
Frostwhite_DB8's Avatar
I agree with the rest above. But I'm going with stock springs since you can adjust the height perch on the Koni Yellows.
Old Apr 6, 2007 | 03:07 PM
If you're looking for installation , call up my friends over at http://www.blacktrax.net . Ask for Natalie or Jei. They're right by Great Mall.
Old Apr 6, 2007 | 05:10 PM
Tornadom's Avatar
Default Re: (Frostwhite_DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frostwhite_DB8 &raquo;</TD></TR><TR><TD CLASS="quote">But I'm going with stock springs since you can adjust the height perch on the Koni Yellows.</TD></TR></TABLE>
I would agree with you, but I honestly think the Konis might have too aggressive dampening for the stock spring rates. I have no experience with off the shelf Koni Yellows, as mine are spss3 valved... I know that my shocks didn't even like to play nicely with 450lb/in springs. I guess I am comparing apples to oranges here, as my shocks are race valved (sort of) but I have heard that even the stock Konis are a bit aggressive. I would like to see some more info on this.
Old Apr 7, 2007 | 01:21 PM
Default Re: (Tornadom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom &raquo;</TD></TR><TR><TD CLASS="quote">
I would agree with you, but I honestly think the Konis might have too aggressive dampening for the stock spring rates. I have no experience with off the shelf Koni Yellows, as mine are spss3 valved... I know that my shocks didn't even like to play nicely with 450lb/in springs. I guess I am comparing apples to oranges here, as my shocks are race valved (sort of) but I have heard that even the stock Konis are a bit aggressive. I would like to see some more info on this. </TD></TR></TABLE>
I'll keep you posted.
Old Apr 12, 2007 | 01:08 PM
Nicks95GSR's Avatar
Default Re: Where to go to get a Suspension job in San Jose (Tornadom)
So all I need is Koni Sports shocks (Yellows) and Ground Control coilovers?? Am i going to be able to adjust the height?? I just want to drop it about an inch and a half.
THANKS HT MEMBERS!!!!
Old Apr 12, 2007 | 01:27 PM
Peter Said's Avatar
yeah youll be able to adjust..
Old Apr 12, 2007 | 01:30 PM
Peter Said's Avatar
coilovers = adjustable
Old Apr 12, 2007 | 07:03 PM
Nicks95GSR's Avatar
Default Re: (Peter Said)
How about Omni Power Coilover Kit - Street Kit ??? Any good??? CHECK IT OUT...
does it come with everything i need???
http://www.prostreetonline.com...t.asp
Old Apr 12, 2007 | 07:29 PM
Nicks95GSR's Avatar
Default Re: (Nicks95GSR)
Old Apr 12, 2007 | 08:18 PM
Jtuned DC2's Avatar
* B A N N E D *
Bro its a lot easier than it seems. Do you have a wide variety of tools?
Old Apr 12, 2007 | 08:19 PM
Jtuned DC2's Avatar
* B A N N E D *
And yes that is good. 5 way adjustables + coilovers Goood
Old Apr 12, 2007 | 08:29 PM
bsdc2's Avatar
Default Re: (KevLo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevLo &raquo;</TD></TR><TR><TD CLASS="quote">Bro its a lot easier than it seems. Do you have a wide variety of tools?</TD></TR></TABLE>
seriously its not hard at all. me and a friend swapped out my springs/shocks and put in omni power coilovers and ITR rear sway in 1.5 hours. granted ive done it before and am pretty familiar with it but any person with a brain can do it. all you need 12mm, 14mm, and 17mm socket and 17mm wrench. beats paying for someone else to do it and plus youll be able to learn how your suspension works
Old Apr 12, 2007 | 08:48 PM
Jtuned DC2's Avatar
* B A N N E D *
Same here. I learned how suspension worked on a honda by expirementing and installing it with some friends.
Old Apr 12, 2007 | 08:51 PM
Nicks95GSR's Avatar
Default Re: (bsdc2)
Whats the differnce between Street Kit and Sport Kit? Which would you guys reccomend???
Old Apr 12, 2007 | 09:23 PM
Nicks95GSR's Avatar
Old Apr 12, 2007 | 11:56 PM
bsdc2's Avatar
difference is spring rate. the street version is 10k/8k while the sport version is 12k/10k. i just installed the sport version and it is stiff. alot stiffer then the tein s-tech springs i used to have. i dont mind the stiffness at all and its alot more enjoyable for me and i plan on doing auto-x/road course so it fit my application. if youre just daily driving i recommend the street version even 10k/8k is stiff enough for most. what are your plans for the car?
Old Apr 13, 2007 | 12:31 AM
Nicks95GSR's Avatar
Default Re: (bsdc2)
Im not really planning to much right now. Im just going along with whatever I think of next. I might go turbo in the future... Cam gears,pistons, cam shafts, manifold (in case I dnt go turbo), headers(" ")
Old Apr 14, 2007 | 01:15 AM
Nicks95GSR's Avatar
I guess Im going with Omni power coilover kit... Just hope pops and I istall it correctly!!!
Old Apr 14, 2007 | 11:20 AM
Search for reviews on suspension before you buy.
Old Apr 14, 2007 | 11:29 AM
bsdc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicks95GSR &raquo;</TD></TR><TR><TD CLASS="quote">I guess Im going with Omni power coilover kit... Just hope pops and I istall it correctly!!!</TD></TR></TABLE>
http://www.team-integra.net/se...D=494
use this as a guide if anything goes wrong, also you can pm me if you have any questions
em1woot
Suspension & Brakes
Dec 12, 2007 04:27 PM
AP_TWO
Dec 19, 2005 07:16 PM
rasta420
14
Dec 4, 2002 04:09 AM
Ricey McRicerton
Jun 17, 2002 10:12 AM
