Skunk2 Throttle Body
Old Apr 6, 2007 | 01:06 PM
Canidinadian-Spec's Avatar
Default Skunk2 Throttle Body
Is it worth it with a Skunk2 Intake Manifold? TB 60mm. IM 62mm. ?
What other TB would be direct bolt-on (no modification) if Skunk2 isn't the best?
This is for a D15B7. Thanks.
Old Apr 6, 2007 | 08:22 PM
Bump. Anything?
Old Apr 7, 2007 | 06:40 PM
bump
Old Apr 7, 2007 | 06:54 PM
Real_E-AT's Avatar
Default Re: Skunk2 Throttle Body (Canidinadian-Spec)
https://honda-tech.com/zerosearch
Old Apr 7, 2007 | 09:37 PM
Tried that...
Old Apr 8, 2007 | 08:31 AM
AMLS4dr200whp's Avatar
Default Re: (Canidinadian-Spec)
62 should be fine with no problem at all
Old Apr 9, 2007 | 10:47 AM
HotboxedTypeR's Avatar
Don't use Skunk2 throttle bodies. I know several people that used them and what happened was that one of the screws from the throttle plate came loose and was sucked into the motor. They were eventually reimbursted by Skunk2, but still not worth the hassle of rebuilding the motor.
Old Apr 9, 2007 | 12:23 PM
UK_Luder's Avatar
Default Re: Skunk2 Throttle Body (HotboxedTypeR)
The new Skunk2 Pro throttle body is supposed to have solved that problem.
Old Apr 9, 2007 | 12:46 PM
formervendor's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotboxedTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Don't use Skunk2 throttle bodies. I know several people that used them and what happened was that one of the screws from the throttle plate came loose and was sucked into the motor. They were eventually reimbursted by Skunk2, but still not worth the hassle of rebuilding the motor.</TD></TR></TABLE>
Have you never heard of a defective product? Things happen.
Just because a tire blows out on you... do you ban that tire forever!
Skunk2, BDL, JG, STR, RPM Services, and the many others all use screws and this can happen to any of them... and probably has. It's gonna happen more to the companies that sell the most throttle bodies... it's statistics.
Old Apr 9, 2007 | 05:06 PM
How about the BBK TB? 62mm?
Old Apr 9, 2007 | 10:41 PM
B20C5 Turbo's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotboxedTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Don't use Skunk2 throttle bodies. I know several people that used them and what happened was that one of the screws from the throttle plate came loose and was sucked into the motor.</TD></TR></TABLE>
I've have yet to experience that with a S2 Throttle body. But I have watched it happen with a Holly unit.
The TRUTH here is that "Bolt on items" do just that; bolt on. It is your responsibility to decide which of those items will produce the best benefit to loss ratio when used with the rest of the components in your SYSTEM. It is also up to you (or your installer) to make sure each part you choose is up to the tasks that your SYSTEM requires from them.
With that said, why the hell would you choose a throttle body as big as the (240hp@9000rpm) S2000 for an engine 3/4 its size that will spin 3/4 the rpm and probably make less than 3/4 it's power? Time to re-evaluate your SYSTEM.
Old Apr 10, 2007 | 08:23 PM
Wow. Totally +1.
You seem to know quite a bit. Props to you.
Old Apr 18, 2007 | 08:13 PM
Real_E-AT's Avatar
Default Re: Skunk2 Throttle Body (Duckiller00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duckiller00 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>1. Seriously who wants to put a defective product on their motors? 2. Firestone - People spend thousands of dollars on their motors why risk putting a "defective" product on your motor? 3. Then don't buy one.
Old Apr 19, 2007 | 07:22 AM
Banned
Default Re: Skunk2 Throttle Body (ChopSuey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChopSuey &raquo;</TD></TR><TR><TD CLASS="quote">1. Seriously who wants to put a defective product on their motors? 2. Firestone - People spend thousands of dollars on their motors why risk putting a "defective" product on your motor? 3. Then don't buy one.</TD></TR></TABLE>
That's just ignorant. One or two or three bad products... make all the parts defective? If you cannot understand the analogy I gave, then I give up. You win. I'm sure you never make mistakes... your parents gave birth to the only perfect person in the world.
deary09
Apr 23, 2013 11:29 AM
jiggacivic
Aug 9, 2011 10:22 AM
SLIM NOTHING
19
Dec 20, 2010 10:36 AM
roudiiboii
May 18, 2010 08:23 PM
b16nonoy
Mar 12, 2007 09:21 AM
