timing belt..........wtf
Old Apr 6, 2007 | 11:51 AM
93egallmotor's Avatar
Default timing belt..........wtf
im finishing up my ls vtec build. installed the cams(bc4) and torqued everything down. now when i put the timing belt on and rotate the motor after a couple rotations the belt slips and puts the cams out of time...any ideas what is going on here?
Old Apr 6, 2007 | 12:46 PM
onepoint6i's Avatar
Default Re: timing belt..........wtf (singlecamy8)
what do you mean it slips?
Old Apr 6, 2007 | 01:58 PM
after i turn the motor over a few times it will eventually jump one or two teeth and out of time
Old Apr 6, 2007 | 04:50 PM
hayabusa160's Avatar
Default Re: (singlecamy8)
take the timing belt off and see if you can turn the cam shafts easly.
samething happen to my friend his head was so warped the cams locked up and wont turn.
Old Apr 6, 2007 | 06:06 PM
do i need to tighten the tensioner up after turning it a few times? it was not tight when it jumped a couple teeth
Old Apr 6, 2007 | 06:11 PM
Runnerdown's Avatar
Cams with stiffer springs aand larger primaries are usually tough to turn over. The belt has to be pretty firm. Also could be binding in the head.
Old Apr 6, 2007 | 06:16 PM
what about the tensioner that i mentioned, does it have to be tight after a few turns?
Old Apr 7, 2007 | 09:21 AM
bump
Old Apr 7, 2007 | 09:25 AM
Padawan's Avatar
Darth ModerVader
http://www.c-speedracing.com/h...t.php
Old Apr 7, 2007 | 10:01 AM
DRAGLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by singlecamy8 &raquo;</TD></TR><TR><TD CLASS="quote">what about the tensioner that i mentioned, does it have to be tight after a few turns?
yes the tensioner needs to be tightened once u take all the slack out of the belt.
Old Apr 7, 2007 | 04:27 PM
Black R's Avatar
25 Year Member
Use the method I use in this thread:
https://honda-tech.com/zerothread?id=1202479
stevenDAtegra
May 7, 2009 09:56 PM
flipdrift
Nov 3, 2008 09:54 PM
boomersz
Apr 5, 2007 11:14 PM
beany
Mar 29, 2006 05:37 AM
hlhneast
Feb 25, 2004 12:48 PM
