need to know if i have a bad injector or wiring ?
i have a rex with stock harness jumper harness for dit and ecu to obdi it has a y8 well ther problem is that its showing me code 16 i changed the injector but it still does the same **** i pulled the clip off the injector (1) and th idle did not change it will not rev pass 3500 rpm the car has no resistor box obd1 injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">If you changed the injector but pulling the clip off doesn't change anything, the problem lies in the wiring.</TD></TR></TABLE>
Ding ding ding!
sings tune**are you smarter than a fifth grader**
Ding ding ding!
SOHCEK-Turbo
Oct 20, 2003 01:20 AM
