type r cams on a gsr motor
Michael D. says
"II. Mild Cam Upgrade: ITR cams
CTR cams differ only with the 1997-1999 ITR cams at the intake VTEC lobe duration ( by only 3 degrees more duration ) and ramp angle..that's it!! The intake max. lift are identical. The exhaust cams for both are identical. :
The 2000-2001 ITR cams are identical to CTR cams.
And yet the 2000-2001 ITR's make identical power to 1997-1999 ITR's!! There's no advantage in getting CTR cams for a B18C. - about 8-10 peak whp gain properly tuned."
Read up http://www.team-integra.net/se...ID=51
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slimjimdanny »</TD></TR><TR><TD CLASS="quote">how many horses would i get if i were to put the type r cams in my gsr? i need to know this because i am buying today</TD></TR></TABLE>
2 ponies and a clydesdale.....if you add the ported VTECH solenoid...then maybe a unicorn!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slimjimdanny »</TD></TR><TR><TD CLASS="quote">how many horses would i get if </TD></TR></TABLE>
I stopped reading there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">Its VTEC not VTECH</TD></TR></TABLE>
No, he is refering to the infamous Ported VTECH solenoid which I invented and "I love lamp." distributed and sold.
change your stock valve springs from your intake and put them on your exhaust,then buy the itr valve springs for your intake side.a gsr motor has dual spring only on the intake side.my friend had them on a 95 gsr motor and dynod at 181 hp to the wheel.he also had a 8lbs flywheel,ctr pulley,spoon wheels(lighter),4 to 1 headers the type r jdm one.apex n1 full catback exhaust straight piped.just letting you know what he did to get 181hp.he used the ctr intake cam and itr exhaust.
not its not... its VTECH.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D »</TD></TR><TR><TD CLASS="quote">
not its not... its VTECH. </TD></TR></TABLE>
+1
+1
I got about 181hp at the wheels as well with ITR cams, S2 intake manifold, aem intake, mugen header, test pipe, S2 exhaust, apex vafc and S2 chipped ecu on a 94 gsr
how much torque.. and what is a 94 gsr stock torque anywas cause i basically have all that you have.. maybe a little more suspension work done but i just wanted to know thanks.
it was 181.3 hp and 125.7 torque at the wheels. i think stock torque is around 115
That was my old car, I am now starting new again as I my old gsr is going to the junkyard, just picked up another 94 gsr. My previous car had alot of suspension work, Tein RS(remote reservoir coilovers, skunk2 rear sway bar, skunk2 lower arm bar, energy suspension bushings, mugen and z speed strut bars, various camber and other adjustment pieces...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraswtrde »</TD></TR><TR><TD CLASS="quote">change your stock valve springs from your intake and put them on your exhaust,then buy the itr valve springs for your intake side.a gsr motor has dual spring only on the intake side.my friend had them on a 95 gsr motor and dynod at 181 hp to the wheel.
he used the ctr intake cam and itr exhaust.</TD></TR></TABLE>
Can anyone tell me if the CTR intake cam is be "better" than an ITR intake cam?
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny »</TD></TR><TR><TD CLASS="quote">
Thanks.
00-01 and ctr intake cams are the same. 3 degrees more duration than 97-98 cams.
Thanks.
</TD></TR></TABLE>00-01 and ctr intake cams are the same. 3 degrees more duration than 97-98 cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
00-01 and ctr intake cams are the same. 3 degrees more duration than 97-98 cams.</TD></TR></TABLE>
Thanks d00d.
Thanks d00d.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D »</TD></TR><TR><TD CLASS="quote">not its not... its VTECH. </TD></TR></TABLE>
It's true I got pictures!
Party pooper....
So if I put an ITR exhaust cam in my B18B1 how many AWHP should I get? You guys should know this right? I mean, this is the ITR forum, you guys know how your parts perform in other motors right!?!?!
<--will feel bad about this in the morning......maybe....
Party pooper....
