Suspension & Brakes Theory, alignment, spring rates....
Polyurethane lube??
Old Apr 6, 2007 | 07:15 AM
c1v1c98's Avatar
Default Polyurethane lube??
My Skunk2 front upper cnotrol arms have started to squeak. Whats the best/easiest lube to use for polyurethane? Is there anything that comes in a pray can?
Old Apr 6, 2007 | 08:02 AM
ES2's Avatar
ES2
Default Re: Polyurethane lube?? (c1v1c98)
You can get a spray can of Dupont Lithium Grease. But just to let you know, the stuff doesn't last very long. I had polyurethane sway bar bushings and switched back to rubber.
EusebioSam19
Suspension & Brakes
10
Dec 25, 2009 04:25 PM
phil_lt1
Nov 8, 2009 08:33 PM
importracer3
28
Jun 19, 2006 08:55 PM
b18C1_liLkyLe
Aug 12, 2003 08:09 PM
hondachick81
Jan 14, 2003 04:55 PM
