225/45/15 hoosier, 15x8 45mm on Integra
Old Apr 6, 2007 | 05:04 AM
crr's Avatar
crr
Default 225/45/15 hoosier, 15x8 45mm on Integra
https://honda-tech.com/zerothread/1945178
Old Apr 6, 2007 | 05:22 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 225/45/15 hoosier, 15x8 45mm on Integra (crr)
You may rub on slightly on the outside of the rears. I mistakenly put 225 40 R16s with Mugen MF* (16z7 with a 43mm offset) on my GSR after reading about King Motorsports ITR in Car & Driver. The outside rears rub slightly and the inside barely clears the springs. Fortunately this only happens when cornering hard and it only contacts the rubber molding. The 225 width is the problem.
Old Apr 6, 2007 | 05:36 AM
crr's Avatar
crr
Default Re: 225/45/15 hoosier, 15x8 45mm on Integra (Dogginator)
I plan on rolling the rear fender lip, so that shouldn't be an issue. It just looks like it might be way close to the trailing arm. The 225/45 hoosier is really wide.
Old Apr 6, 2007 | 08:56 AM
AViciousTHRUST's Avatar
where can you get these tires, and would they fit on 6.5" konig heliums with a 38mm offset
Old Apr 14, 2007 | 10:16 AM
Black R's Avatar
25 Year Member
Default Re: 225/45/15 hoosier, 15x8 45mm on Integra (AViciousTHRUST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AViciousTHRUST &raquo;</TD></TR><TR><TD CLASS="quote">where can you get these tires, and would they fit on 6.5" konig heliums with a 38mm offset</TD></TR></TABLE>
omg..... try http://www.tirerack.com and do some reading here on h-t!
Ultraspeed DC2
Sep 1, 2008 11:38 AM
FrostyDC4
Oct 1, 2004 05:40 PM
hondapwr
Aug 25, 2004 08:12 AM
01PYTypeR#1140
Feb 17, 2004 04:27 AM
gary201147
May 28, 2003 02:15 PM
