Offset for MF10s
Old May 28, 2003 | 01:20 AM
gary201147's Avatar
Default Offset for MF10s
I've been torn between the two offsets offered by Mugen for their Mf10s. They offer a +43 and +50. Now I've been recommended STRONGLY to get the 43 from RandD but STRONGLY recommeded by King to use the +50. (THis may have something to do with the fact that they stock those) But anyways, isnt more versatile to use the 50 and then a spacer? You dont have to worry about rubbing the fender when running wider tires and can fit equally as large calipers that would fit in a 43.
Any other ideas of pros and cons would be welcome. Thanks
Old May 28, 2003 | 04:59 AM
kalel's Avatar
Default Re: Offset for MF10s (gary201147)
Reading some members here at HT that use MF10's on their R(below are their comments) Hope it helps your decision.
From BPR
"I have 225/40 street tires on the +50 mm offset 16x7 MF-10s. No rubbing that I can detect. The +43mm offset push the rim outwards 7 mm - so the widest you can go on those is 215/45 unless you roll the fenders in the rear."
From Austin
"I run the +43mm...with the 215-45/16 Azenis I had some rubbing on the inner front fender(body)...but the rubbing was slight. Mugen recommends +50 for street, and +43 for track...I bought mine used before I had any clue...but for the amount I paid it didn't matter ."
From EP
"i run the 43's but the fenders need some trimming"
Old May 28, 2003 | 09:02 AM
arren123's Avatar
Default Re: Offset for MF10s (kalel)
I run have the +50mm and 215-45/16 Azenis and I also have some rubbing on the inner front fender(body)... I just bought 5mm spacers to help a little
Old May 28, 2003 | 10:11 AM
Big Phat R's Avatar
Default Re: Offset for MF10s (arren123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arren123 &raquo;</TD></TR><TR><TD CLASS="quote">I run have the +50mm and 215-45/16 Azenis and I also have some rubbing on the inner front fender(body)... I just bought 5mm spacers to help a little</TD></TR></TABLE>
Azenis are an unusually wide tire - so this example is not typical.
The difference in overall track width between the two offsets is 14 mm = ~3/4"
The 43mm offset will fit a 215 width tire
The 50mm offset will fit a 225 width tire (which makes up for offset difference anyways)
If you're planning a brake upgrade - get the +43 mm offset for maximum caliper clearance.
Old May 28, 2003 | 10:14 AM
IGGY's Avatar
Default Re: Offset for MF10s (Big Phat R)
Would that mean spoons calpiers too?
Old May 28, 2003 | 10:18 AM
Big Phat R's Avatar
Default Re: Offset for MF10s (IGGY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY &raquo;</TD></TR><TR><TD CLASS="quote">Would that mean spoons calpiers too?</TD></TR></TABLE>
yes
Old May 28, 2003 | 10:34 AM
FAST4DR's Avatar
With the 205/45s you ordered, I would STILL recommend the 43 offset.
Old May 28, 2003 | 10:40 AM
Big Phat R's Avatar
Default Re: Offset for MF10s (FAST4DR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAST4DR &raquo;</TD></TR><TR><TD CLASS="quote">With the 205/45s you ordered, I would STILL recommend the 43 offset.</TD></TR></TABLE>
If you're only using 205s - I would too
Old May 28, 2003 | 01:30 PM
DutchITR1689's Avatar
Mugen offers +50 mm offset so you can keep the wheel/suspension geometry same as stock, like track width, scrub radius etc.
Old May 28, 2003 | 02:03 PM
arren123's Avatar
Default Re: Offset for MF10s (DutchITR1689)
I don't know.. With the 5mm spacers and stock ITR wheels, it feel like that I have more grip around corners. I still have to try the Mugen MF10's w/spacers. So far it "feels" like with the wider track, i have more grip available, but I won't be able to compare until I go to the next autocross.
But I have a feeling that the extra track by using the +43 mm offset is worth it. (I have no real basis for this opinion though)
Old May 28, 2003 | 02:15 PM
Big Phat R's Avatar
you get a whopping 3/4" of extra track.
i think you're imagining things.
gg emerican
Honda Civic (2006 - 2015)
Mar 28, 2009 08:08 AM
an2ny888
Jul 19, 2005 06:15 PM
hondapwr
Aug 25, 2004 08:12 AM
Rembrant Q. Einstein
May 15, 2002 05:44 AM
kkim
Apr 5, 2002 03:29 PM
