convert 94 integra headlight to 98 integra headlight?
what do i need to convert my 94 headlight to 98 integra?
i change the headlight and the bumper? is that all i need to change?
you need to search, but i'll help you out. you need the bumper, corner lights, corner light brackets, and headlights, and you're set.
so i dont need to replace my fender..cause i heard that i need to change it... i just want to make sure....thanks...for the help...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnuanz382 »</TD></TR><TR><TD CLASS="quote">so i dont need to replace my fender..cause i heard that i need to change it... i just want to make sure....thanks...for the help...</TD></TR></TABLE>
no
no
does it matter if four door 98 bumper or it dont matter??? so 98 headlight, 98 bumper and 98 comrner light...does the fitting is perfect?? like factory??? thanks for the help ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnuanz382 »</TD></TR><TR><TD CLASS="quote">does it matter if four door 98 bumper or it dont matter??? so 98 headlight, 98 bumper and 98 comrner light...does the fitting is perfect?? like factory??? thanks for the help ...</TD></TR></TABLE>
all 98 bumpers are the same doesn't matter if its 4dr. or 2 dr. and the fitting issue idk
when i put the 98 bumper to the 94 integra iremove the front beam ...i just want to known if theres anyway that i can install the bumper without removing the front beam???
umm there's no front beam to take off, just take off the old bumper and put on the new one, it's just a few bolt/screws... it really is that easy
If you get the bumper from another teg, you probably won't need the corner light bracket because it will already be installed. I got my bumper from the dealer, so I had to get the bracket as well. It's what you slide the front most end of the corner light into. You'll also need the tinnerman(sp?) nut off your old bumper if you buy new to hold the screw to the bumper. It's the clip type nut that slide over the plastic hole that the screw goes through. Don't forget to do the rear bumper too, since the 98 rear looks 10x better as well. All you need is the bumper for the rear, but you can't use a 4 door rear bumper, has to be two door.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skip’sDC2 »</TD></TR><TR><TD CLASS="quote">thanks for this thread. i was going to make one for myself until i saw this one. any different in the 2 and 4 dr version ?</TD></TR></TABLE>
Why would you make another thread!!!
If you would just search you will find a bunch of thread like this and alot of people saying the same crap I'm saying right now. =X Anyhow there is no diffrence in the front bumper for coupes/sedan but the rear are diffrent. I mean look at the car! It's quite obvious that they are diffrent unless you customized it to make it fit the coupes but why would you do that it would cost 4x if not more just for that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98BabiGs-T »</TD></TR><TR><TD CLASS="quote">
If you would just search you will find a bunch of thread like this and alot of people saying the same crap I'm saying right now. </TD></TR></TABLE>
noobs will never learn
If you would just search you will find a bunch of thread like this and alot of people saying the same crap I'm saying right now. </TD></TR></TABLE>noobs will never learn
