rex cutting up
Old Apr 5, 2007 | 11:22 PM
BlueRex1020's Avatar
Default rex cutting up
hey guys i'm having some trouble with my rex....when i first start it n its cold it starts to cut up but after a few mins it drives fine....n i'm getting code 13 on my ls ecu which is da baro sensor n da code came up when i first had this problem....do u guys think dat might be the issue? its just a dx obd1 n mpfi...
Old Apr 5, 2007 | 11:24 PM
Default Re: rex cutting up (BlueRex1020)
oh n it starts to cut up while i'm first driving n its still cold....
Old Apr 6, 2007 | 09:20 AM
anyone? i need help on this one..
Old Apr 6, 2007 | 09:51 AM
gRim06's Avatar
I'm having the same problem but i believe it has something to with the integra gs ecu i just swapped for old in my dohc zc rex. As soon as i crank it (first crank in the cool morning) the rpm goes straight down and dies if i don't give it gas, and then if i dont get it warmed up good and the engine is still kinda cold it dies when i push the clutch in to shift or stop. If any one could help out with some advice, it'd b great.
Old Apr 6, 2007 | 11:44 AM
Default Re: rex cutting up (gRim06)
bump...
Old Apr 6, 2007 | 11:53 AM
wiZCo's Avatar
Stouts 'n' Scotch
Not sure what the 'baro sensor' is.... MAP sensor maybe? Baro-->Barometer-->Pressure.... well anyways, obviously whatever's throwing the code is causing your car to run poorly. Clear up the CEL.
Old Apr 6, 2007 | 08:57 PM
Default Re: (wiZCo)
i need help "clearing up the cel" or else i wouldnt ask n i think code 13 which is dat baro sensor is diff than map sensor
Crazed-Sol
Mar 12, 2013 08:54 PM
jdm91CrxSi
Apr 18, 2006 03:02 PM
crxdriver89
20
Sep 7, 2005 02:00 AM
Beyond Imagination
Feb 20, 2005 09:05 PM
