WTB: OBD2 gsr Purge solenoid, oil pump, CKF, crank gear T-belt cover,
for USDM OBD2 gsr, Purge solenoid, oil pump with mounts for the CKF, the CKF, the usdm crank gear and key, and the lower timing belt cover for the usdm gsr/type r. I need this to pass Ref, so its got to be OBD2, and its got to be USDM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sacicons »</TD></TR><TR><TD CLASS="quote">for USDM OBD2 gsr, Purge solenoid, oil pump with mounts for the CKF, the CKF, the usdm crank gear and key, and the lower timing belt cover for the usdm gsr/type r. I need this to pass Ref, so its got to be OBD2, and its got to be USDM. </TD></TR></TABLE>
I have a used oil pump, ckf sensor and gear. No key, but those are cheap at the dealer. I don't have the lower timing cover. In Sacramento area, let me know.
Uljima
Nov 2, 2023 09:19 PM
2kgs-R
Mar 6, 2007 08:36 AM
