brake fluid ??
yep, ^^ is correct.
If your pads are starting to get close to needing to be replaced, you'll need to add brake fluid.
So check them out. If they still look pretty new, you may have a leak in the system.
when is the last time you changed your pads?
i jusr replaced them and the place i got them changed at just said i was low on brake fluid the car has never had it changed since i had it for 12 k miles so im just guessing i need to add some
If your not real sure about why the brake fluid is low and aren't very mechanical, I would take it into honda/acura and have them take a look at it. I really wouldn't screw around with something as important as brakes if you don't understand the problem.
~Ben
~Ben
brake fluid does not evaporate like coolant/water. you are low on fluid for one of 2 reasons.
you have a leak. or your brake pads are low/worn.
have your complete braking system checked out.
