what color are the rings on the 97 + h22 injectors
Old Apr 5, 2007 | 06:56 PM
djsire's Avatar
Default what color are the rings on the 97 + h22 injectors
I need the ones that "Dont" use a resistor box.
Also are the plug and play with an obd1 harness?
Old Apr 6, 2007 | 08:42 AM
djsire's Avatar
Default Re: what color are the rings on the 97 + h22 injectors (djsire)
anyone
Old Apr 6, 2007 | 10:39 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">I need the ones that "Dont" use a resistor box.
Also are the plug and play with an obd1 harness?</TD></TR></TABLE>
OBDII doesnt use a resistor and its a "rounded" plug
OBDI is a squared plug
they will not plug and play.
Old Apr 6, 2007 | 11:06 AM
preludestud11's Avatar
Default Re: what color are the rings on the 97 + h22 injectors (98vtec)
use a multimeter and check the resistance between the 2 metal prongs. ~2.4 ohms= saturated, obdII from 96+h22's, ~14.5 ohms=peak and hold from 91-95 h22's.
Old Apr 6, 2007 | 02:14 PM
Jim Truett's Avatar
Default Re: what color are the rings on the 97 + h22 injectors (preludestud11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludestud11 &raquo;</TD></TR><TR><TD CLASS="quote">use a multimeter and check the resistance between the 2 metal prongs. ~2.4 ohms= saturated, obdII from 96+h22's, ~14.5 ohms=peak and hold from 91-95 h22's.</TD></TR></TABLE>
You have that backwards.
2-3 ohms is peak and hold.
12-15 ohms is saturated.
Old Apr 6, 2007 | 10:05 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: what color are the rings on the 97 + h22 injectors (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
12-15 ohms is saturated.</TD></TR></TABLE>
No sir, you have it wrong.
Old Apr 7, 2007 | 02:16 AM
djsire's Avatar
Default Re: what color are the rings on the 97 + h22 injectors (cb7-R)
so whats the final word on the omage?
Old Apr 7, 2007 | 07:16 AM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R &raquo;</TD></TR><TR><TD CLASS="quote">
No sir, you have it wrong.</TD></TR></TABLE>
No, I actually work on cars, I'm not just an internet mechanic.
Maybe RC Engineering has it wrong too....
http://www.rceng.com/prices.htm
More:
http://www.robietherobot.com/S...e.htm
More:
http://hondaswap.com/general-t...0347/
Old Apr 9, 2007 | 10:30 AM
Speedra500's Avatar
peak and hold on the OBD Is are suppose to be low impedence, not taking into account the resistor box. I have not actually measured it myself but I would assume the lower of the two would be the P&H. Since the saturated injectors have no resistor box they would have to have more resistance to account for an equal electrical load. So it seems logical that it would be that way. Maybe you were taking into account the resistor box too?
Old Apr 18, 2007 | 09:24 AM
djsire's Avatar
wow now im more confused.
can somone just tell me the color of the rings!!!!
i want the ones that Dont need a resistor box.
Old Apr 18, 2007 | 09:25 AM
djsire's Avatar
and what do i need to to to run them off a p13 obd1.
(do i just swith the connectors?)
Crx Jimmy
Aug 2, 2008 08:07 AM
djsire
Apr 6, 2007 08:42 AM
Corporation
Jun 14, 2005 12:08 AM
94lsboost
Apr 7, 2005 07:07 AM
VRD^don
Dec 7, 2004 09:49 AM
