Suspension
Please no flames from the AutoXer's/RR's. What is the best setup to lower the car about 2 inches, maybe 1.5 and be setup for street fun and the drag strip. Mostly just want the benefits of a better launch, however, i dont want to lose any handling performance... stock handling is just good enough....
Thanks,
Jon
Thanks,
Jon
A few questions...
#1 - Isn't it bad to run just springs... i thought that messes something on the suspension up down the line.
#2 - I AM not looking to gain any handling performance (the suspension is already perfect for that), however... I DO want to get a suspension that will help me with my launching for drag.. i heard suspension could make quite a difference when dragging...
#3 - How much of a drop do the Spoon/H&R Sport springs lower the car? how many inches?
Thanks,
Jon
Thanks,
Jon
A few questions...
Thanks,
Jon
Thanks,
Jon
#2- see #1
#3- they both lower the car between 1.5" and 1.75" if I remember correctly.
Spoon springs are the way to go. They were designed to work with the stock shocks. They will give your car a nice drop. Since you want to launch better at the dragstrip, I would suggest some slicks and the Z10 Engineering radius bar.
Do a search about the radius bar, the bar will virtually eliminate wheel hop.
Here's Z10's site: http://www.z10eng.com/index2.htm
HTH
HTH
Is that Z10 Radius Bar the thing I see draggers using to prevent them from doing wheelies (the thing that hangs off of the back)... I am a little confused about this piece. I looked at the site, and I couldn't find what it was... where does it go?
Could someone also help me find out some things about the springs....
Spoon Springs-
How much of a drop?
How much do they cost?
H&R Springs-
How much of a drop?
What motor mount inserts are recommended?
Thanks for the help,
Jon
Spoon Springs-
How much of a drop?
H&R Springs-
How much of a drop?
Jon
Z10 Radius Bar:
Bolt-On Traction Uses Factory Bolt Holes
Completely Eliminate Wheel-hop
Launch Harder, Lower 60’ times
Retains Complete Suspension Travel—No Binding
CNC Machined Components, TIG Welded Crossmember
Retains Factory Ground Clearance
Allows for Caster Adjustment
Suitable for both Road Race and Drag Race Applications
Includes ALL HARDWARE needed for complete mounting, and Clevises for the lower control arm.
Stops forward/backward movement of the lower control arm, strengthening the lower control arm assembly.
Allows you to adjust caster
Negates the need to install poly bushings.
Stops wheel-hop completely
Follows the same arc as the stock suspension,
Will not lock the front end up. Ground clearance is
identical as stock, Good for Road race or drag race.
I dont think there is any springs(non-adjustable) out there that will lower the ITR 1.5"-2" more. If you want it slammed to the ground that much you will need some adjustable coilover kit. Ground Control, Skunk2, etc...
hooptie157
Jun 4, 2002 07:35 AM
