I'M ABOUT TO THROW IN THE TOWEL!
Old Apr 5, 2007 | 04:49 PM
Fighterinsnatch's Avatar
Default I'M ABOUT TO THROW IN THE TOWEL!
Ok I've been trying to get my civic running good. I swapped a D15b Vtec and the damn thing pulls like its a d15 non vtec.
1) Car pulls really sluggish like its not getting enough air to fuel
2) Vtec does'nt engage at all. I once got it to engage and I could feel a huge kick(no lie)
3) Car backfires badly
1992 Civic Si D16z6 ecu with D15b Vtec motor
I have replaced the entire vtec solenoid. I have replaced the PCV valve. I have put in fuel injection cleaner. Oil is topped off.
NOTHING GIVES! NOTHING!
I'm begging for help here. I love my car and I hate that I cant get the motor running strong. I have put blood and sweat into this car.
Any help would be much much appreciated. Anyone who actually helps, I will have my g/f make you a batch of her AWESOME AWESOME caramel and nut BROWNIES!
Old Apr 5, 2007 | 04:52 PM
pdiggitydogg's Avatar
how is your timing? belt set correctly?
Old Apr 5, 2007 | 04:57 PM
95hatchcivic's Avatar
I have the correct ecu for your d15b vtec if your interested..i will trade you for your p28 (d16z6) I HAD a d15b vtec and blew it, swapped out for d16z6..
wanna swap ecu's??
Old Apr 5, 2007 | 05:04 PM
Yes we checked my timing and it was dead on.
95hatchcivic. What exactly are you saying? You want my D16z6 ecu for your blown D15bVtec ecu? I don't get it.
Old Apr 5, 2007 | 05:08 PM
smileycvc's Avatar
Default Re: (Fighterinsnatch)
First off are you running the right ecu?
Old Apr 5, 2007 | 05:13 PM
Default Re: (smileycvc)
Well I think so. I have the ecu from a D16z6 ecu. How can I check what ecu I have? I'll go check right now.
Old Apr 5, 2007 | 05:17 PM
John M's Avatar
THERE IS YOUR PROB LOOK ON YOUR ECU IT SHOULD SAY P28 THAT MEANS U GOT THE WRONG ECU
Default Re: (John M)
Ok i'm going to check now.
Old Apr 5, 2007 | 05:18 PM
the ecu will have a slew of numbers on a sticker
if its a p28, it will say p28
Old Apr 5, 2007 | 05:20 PM
spork motorsports's Avatar
* B A N N E D *
if it is a p28 then check your injector plugs, reset the ecu, check the plugs on the solenoid you might have mixed the 2
check spark plugs, you have alot of things to check, first thing MAKE SURE THE TAG ON YOUR ECU LOOKS LIKE THIS!!!!!!!!!!!!!!!!
XXXXXX-p28-xxxxxxx
Old Apr 5, 2007 | 05:23 PM
Where is the actually ecu number at? I can't find it.
Old Apr 5, 2007 | 05:26 PM
Where is the ecu actually at? I can't believe I'm asking this question. For some reason I thought it was the fuse box. wow.
Old Apr 5, 2007 | 05:32 PM
novtecnoboost's Avatar
i think it is time to throw in the towel and buy a kia.
but this is ht.
its behind ur kick panel on the passenger side of ur car.
right where ur feet go on the right side
just pop it off
Old Apr 5, 2007 | 05:39 PM
Default Re: (theb18c1)
lol.
Ok it is P28.
Old Apr 5, 2007 | 06:30 PM
Bump
Old Apr 5, 2007 | 06:34 PM
WHY R U BUMPING swap in the right ecu and u will be fine
Old Apr 5, 2007 | 06:54 PM
MonkeyBoy668's Avatar
Take 95hatchcivic up on his offer, or get the correct ECU from another source.
I don't think he's saying his ECU blew, he's saying he blew his engine, so he's got a working ECU for you just lying around that will work in your application, and probably needs a P28 for his new project. Hence the swap makes sense for the two of you.
Of course I don't know 95hatchcivic any better than you do, I'm always leery of taking random internet people up on offers... but sometimes you get lucky.
Old Apr 5, 2007 | 07:03 PM
Jonknee's Avatar
Default Re: (MonkeyBoy668)
Why are we arguing over the ecu, The p28 is fine for the d15bvtec, sure the p08 is better but they are too similar, Fuel maps are the only slight difference. Ive been running a p28 on a d15bvtec for over a year now.
You're not getting any ecu codes for distributor?
Old Apr 5, 2007 | 08:21 PM
aqm28's Avatar
Default Re: (pdiggitydogg)
how are you checking your timing? you have a jumper wire by ecu.
Old Apr 5, 2007 | 08:42 PM
I'm not getting any codes now. I had a IAT code and oil pressure sensor code.
I cleaned the IAT and replaced the vtec solenoid and the codes cleared out.
We checked the timing with a timing gun.
Old Apr 5, 2007 | 09:11 PM
sol2hatch's Avatar
i am running a p28 with my d15b, and its just fine. Your ecu doesnt sound like the problem. Your timing might be off, and have you checked to see that its firing on all cylinders? check plugs and wires. Does the exhaust sound funny?
Old Apr 5, 2007 | 09:25 PM
maynards_ek's Avatar
Default Re: (sol2hatch)
Check your ignition components. You might want to change your fuel filter too. I didn't know you could run a d15 with a p28.
Old Apr 5, 2007 | 09:36 PM
sol2hatch's Avatar
Default Re: (maynards_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maynards_ek &raquo;</TD></TR><TR><TD CLASS="quote">I didn't know you could run a d15 with a p28.</TD></TR></TABLE>
its the JDM d15b SOHC VTEC motor. Its basically the same as our d16z6, just upped comp. a little bit I believe.
Old Apr 5, 2007 | 11:21 PM
jdmray's Avatar
i know it sounds stupid but check all your ground wires
Old Apr 6, 2007 | 12:12 AM
Johnny Ricer's Avatar
Default Re: (jdmray)
well he may be able to run that ECU but did anybody think that maybe his ecu is f*ucked up somehow?
