Only one headlight comes on at night, is this a wiring issue?
Old Apr 5, 2007 | 03:01 PM
EscaBoi's Avatar
Default Only one headlight comes on at night, is this a wiring issue?
Hey, i'm not sure if this is a wiring issue.
My day time headlights work fine on both sides, but when i turn on my night lights only one headlight works, is it a wiring issue?
DAY
NIGHT
Old Apr 5, 2007 | 03:03 PM
philosofy1's Avatar
Default Re: Only one headlight comes on at night, is this a wiring issue? (EscaBoi)
most likely since 5th gen civic never came with daytime running lights.
Old Apr 5, 2007 | 03:06 PM
Lord Milferdeen's Avatar
**** my cars doing that too
Old Apr 5, 2007 | 03:16 PM
philosofy1's Avatar
Default Re: Only one headlight comes on at night, is this a wiring issue? (Lord Milferdeen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Milferdeen &raquo;</TD></TR><TR><TD CLASS="quote">**** my cars doing that too </TD></TR></TABLE>
have you even tried replacing the bulb, come on, it's common sense.
Old Apr 5, 2007 | 03:27 PM
h2392si's Avatar
Default Re: Only one headlight comes on at night, is this a wiring issue? (philosofy1)
Probably a fuse underneath the dashboard, by the drivers side. I thinks its a 13. This happended to me the othe day and i bought new headlights but when i replaced them, still did not work. Then i started to look at all the fuses and there it was, a burn fuse. Oh well, at least got new bright bulbs. Try abother bulb on the headlight too, that way if it doesnt work you can rule out the bulb. Good luck.
Old Apr 5, 2007 | 03:37 PM
EscaBoi's Avatar
alright thanks, i'll check the fuse tomorrow morning
Old Apr 5, 2007 | 03:56 PM
Harryflores's Avatar
Default Re: Only one headlight comes on at night, is this a wiring issue? (h2392si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2392si &raquo;</TD></TR><TR><TD CLASS="quote">This happended to me the othe day and i bought new headlights but when i replaced them, still did not work.</TD></TR></TABLE>
WTF !!! new headlights for a fuse problem
Old Apr 5, 2007 | 08:17 PM
GOTSUBZ's Avatar
swap the bulbs first and try ur lights
do u mean when u put ur headlights on they both show up and then when u put ur high beams only one comes on? or visa versa?
if swappin the two bulbs doesnt work then check your fuses.
Old Apr 5, 2007 | 08:32 PM
ridin98civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EscaBoi &raquo;</TD></TR><TR><TD CLASS="quote">
DAY
those look really bright for DRL's
Old Apr 5, 2007 | 08:57 PM
yes because they make 3 filament bulbs
Old Apr 5, 2007 | 09:06 PM
Striker_1818's Avatar
how the hell did u get DRL's on your 92-95 civic?
Old Apr 5, 2007 | 09:14 PM
Default Re: (Striker_1818)
All civics in canada have em as soon as you release the e-brake.
Old Apr 5, 2007 | 10:04 PM
GOTSUBZ's Avatar
Default Re: (Lord Milferdeen)
i had no idea EGs had em in canada
u learn sumthin new eryday
Old Apr 5, 2007 | 10:34 PM
Default Re: (GOTSUBZ)
i know his bulb is fine otherwise the DRLs wouldn't work hence its a filament H4 bulb and it will obviously use his low for low power which the DRL's are low currents to make the bulb light up but not to its 55w intensity... but then again with an H4 bulb you have a ground, positive low beams and hi beams... meaning the low positive could be the problem...
This is basically our H4 design with the 3 tabs on the bulb:
Ground:..........|.....|........ : High beam Positive
Low positive: ....._...
Am i making sense?
Maybe his DRLs are connected along w/the high and low positive part...
sucks
Old Apr 6, 2007 | 12:19 AM
Johnny Ricer's Avatar
wait daytime was taken after the nightime pic on the same day just one minute later.??? WTF
Old Apr 6, 2007 | 12:41 AM
ekb16a's Avatar
thats ur relay i think check that
Old Apr 6, 2007 | 12:46 AM
Default Re: (soundpsych)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundpsych &raquo;</TD></TR><TR><TD CLASS="quote">wait daytime was taken after the nightime pic on the same day just one minute later.??? WTF </TD></TR></TABLE>
he was stating that the day pic was of his DRL's
and that the night pic was of his regular headlights
Old Apr 6, 2007 | 05:08 AM
Do u think that ground could also have somethin to do with my subs cutting out on occasion??
Old Apr 6, 2007 | 05:12 AM
93egsir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">most likely since 5th gen civic never came with daytime running lights.
do you look where he is from Canada. As far as I am aware most if not all veh in canada have to have daytime running lights.
Old Apr 6, 2007 | 05:13 AM
93egsir's Avatar
I would start at the plug and work back could be just a ground. Are they oem wattage bulbs if not you could have melted the plugs.
are the daytime running lights oem or aftermarket equipment??
Old Apr 6, 2007 | 06:50 AM
h2392si's Avatar
Default Re: Only one headlight comes on at night, is this a wiring issue? (93egsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harryflores &raquo;</TD></TR><TR><TD CLASS="quote">
WTF !!! new headlights for a fuse problem </TD></TR></TABLE>
Sorry, new headlight bulbs.
Old Apr 6, 2007 | 06:51 AM
hatchness135's Avatar
have you even tried replacing the bulb, come on, it's common sense.</TD></TR></TABLE>
kinda what i was thinking...that and someone said to check the fuses
Old Apr 6, 2007 | 07:14 AM
civicminded311 EK's Avatar
for those that didnt know, DRL are required by the DOT on all canadian built and reqistered cars.
Old Apr 6, 2007 | 07:15 AM
i would check resistance on the grounds...
Old Apr 6, 2007 | 08:12 AM
yeah get a clean metal ground on the chassis...
