b18a1 swap????
Old Apr 5, 2007 | 03:00 PM
SETxTHExSTAGExEJ1's Avatar
Default b18a1 swap????
im swaping a stock b18a1 into a 95 civic coupe could i use all the mounts from the DA into my civic?? would it work?? it kinda doesnt look like it would but i have a few freinds telling me it will and some that it wont
Old Apr 5, 2007 | 03:07 PM
Danronian's Avatar
No it won't work at all. You need either integra mounts from a 94+ integra, or swap mounts for your civic.
The cable tranny will not work unless you swap the cable clutch pedal parts into your car and you can get an adapter to mount the correcty tranny mount onto so that it will bolt up correctly. You'll also need 90-93 axles instead of the 94 ups if you use the cable tranny.
Old Apr 5, 2007 | 03:30 PM
Suck my DX's Avatar
Default Re: (Danronian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danronian &raquo;</TD></TR><TR><TD CLASS="quote">No it won't work at all. You need either integra mounts from a 94+ integra, or swap mounts for your civic.
The cable tranny will not work unless you swap the cable clutch pedal parts into your car and you can get an adapter to mount the correcty tranny mount onto so that it will bolt up correctly. You'll also need 90-93 axles instead of the 94 ups if you use the cable tranny.</TD></TR></TABLE>
or you can make a custom bracket and use your hydraulic slave cylinder to actuate the clutch lever on the cable tranny...
Old Apr 5, 2007 | 03:35 PM
thanks thats what alot of people told me i wasnt to sure till now
Old Apr 5, 2007 | 03:44 PM
Danronian's Avatar
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">
Yup...that would be easier.
I have heard lots of issue with doing this, but you could be a lucky one!
Old Apr 5, 2007 | 04:09 PM
Suck my DX's Avatar
like what?
pretty much you have to make the bracket that holds the slave cylinder slightly adjustable to fine tune the clutch engagment/disengagment point...also ive seen it helpful if you can weld on a holder for the slave cylinder on the clutch lever to hold the cylinder in place and still run the rubber boot( so dirt stays out)...
its not too difficult, just a little time consuming....not bad if you cant find a decent hydro tranny
AudioXtremes
Jul 24, 2006 11:02 AM
90teg
Aug 1, 2005 10:32 AM
drumking15
Jan 16, 2005 05:00 AM
90dxhatch
Jun 17, 2004 10:41 AM
