about 2 give up on my crx project ! need opinion on rust issues.HELP!
whats up? put alot of time into this crx . the body is all good . and the only issue is the front window. where someone put a replacment window in and a sloppy install caused a water trap around the caulk. i want to do this project right . and would hate to get this done and rust come back. (like it ussually does)..[IMG][/IMG]
these pics are taken after the window was removed ,then.. wire wheeled ,..then grinded
Pictures are too small. From what I can see though it looks pretty bad. I worked on a 57 chevy once that was like that. All I did was cut new metal in to replace it. But if its a pillar make sure you weld a bar in to temp. hold the roof up. Because trust me it WILL flex.
I would cut all the rust out, weld in new stuff (maybe find a donor car to cut a perfect filler from) Then coat it in por15 to prevent furhter rusting
4twenty_CRX
Sep 28, 2007 04:38 PM
