does valve cover need to be torqued?
Old Apr 5, 2007 | 12:17 PM
Eibach95Civic's Avatar
Community Builder
Default does valve cover need to be torqued?
any certain lbs?
Old Apr 5, 2007 | 12:18 PM
amej8's Avatar
The 5 bolts that hold it down? Yes, there is a certain number. I just can't recall it right now .
But I've taken my valve cover off over a dozen times now and I've never torqued it. If you don't torque it like I do, just don't over tighten because they snap EASILY.
ninajedit - eh was bored and searched for yah. 7lbs.
Old Apr 5, 2007 | 12:20 PM
Community Builder
Default Re: (amej8)
yeah the five bolts. I just wasn't for sure
Danronian's Avatar
Also known as barely tight with the 1/4 drive. I find if I use anything bigger than the 1/4inch drive, I overtighten them, and then it leaks...
Old Apr 5, 2007 | 12:21 PM
amej8's Avatar
Also be sure to use hondabond on the 4 corners when putting it back on. Then let it sit for at least 30 minutes before starting the car so the hondabond can "cure". And by the way I edit'd my first post and put it in there for yah.
Old Apr 5, 2007 | 12:23 PM
Community Builder
Default Re: (amej8)
haha thanks buddy. this "hondabond" what exactly is it and can I get it at an Auto Zone or something?
Old Apr 5, 2007 | 12:32 PM
amej8's Avatar
To be honest, I have no idea where you can get it. In the past, I've worked on my car with a few buddies so they always just gave me their stuff.
But it's like a sealant to prevent leaks. Hence why you should let the valve cover sit on the car for a while before turning the car on so you don't disrupt the hondabond settling/curing.
Old Apr 5, 2007 | 12:33 PM
Boostedb20EH2's Avatar
Default Re: (Eibach95Civic)
Hondabond is a sealant for pretty much everything on your car haha. And its sold at a honda dealership. There is something sold at autozone called rvt silicone or something like that.. But hondabond works better.
lmike6453
Mar 9, 2008 08:18 AM
LankorDie
Aug 23, 2004 08:33 PM
bzyrice
Dec 6, 2003 09:05 AM
TeamTooQuick
May 18, 2002 08:18 AM
FUP23
May 13, 2002 05:46 AM
