take it off, baby.
Old Apr 5, 2007 | 12:03 PM
Mandark06's Avatar
Default take it off, baby.
anyone know how i can disable and remove my cruise control??? i never use it and it's just getting in the way right now. thanks.
Old Apr 5, 2007 | 12:08 PM
MR.johnson's Avatar
Default Re: take it off, baby. (Mandark06)
look at it and then take it off.
its not hard.
a 8 year old could do that.
Old Apr 5, 2007 | 12:11 PM
Mandark06's Avatar
Default Re: take it off, baby. (MR.johnson)
= P well that's kind of a give, but are there any electrical factors involved? resetting fuses or anything? that's what i meant to ask = / sorry. thanks though, haha.
Old Apr 5, 2007 | 12:24 PM
Danronian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson &raquo;</TD></TR><TR><TD CLASS="quote">look at it and then take it off.
its not hard.
a 8 year old could do that.</TD></TR></TABLE>
It IS that easy. Just unplug the stuff for the cruise, and never worry about it ever again. DON"T cut anything! Because you don't need to.
Old Apr 5, 2007 | 12:25 PM
amej8's Avatar
It's almost self-explanitory. Just get in the engine bay and look around. The hardest part is when you have to get on your back and look up behind your dash and unhook the wire from the gas pedal. Use pliers when you do so. I tried using my fingers and it just gave me the worst backache and neckache. I got it off within a minute using pliers.
Old Apr 5, 2007 | 12:29 PM
JDM-EJ1's Avatar
Default Re: (amej8)
Everything posted in this thread thus far is correct.
Old Apr 5, 2007 | 12:32 PM
pdiggitydogg's Avatar
only thing that you will need to take into consideration, is the fact that unless you block the vacuum port, you will have a leak...
Old Apr 5, 2007 | 12:33 PM
amej8's Avatar
That's where electrical tape becomes your best friend .
Old Apr 5, 2007 | 10:25 PM
Mandark06's Avatar
Default Re: (pdiggitydogg)
vacuum port??? o.O
the rest sounds easy enough thanks guys.
Old Apr 5, 2007 | 10:27 PM
sol2hatch's Avatar
Default Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Everything posted in this thread thus far is correct.</TD></TR></TABLE>
lmao, I like how he comes in to just to put his stamp of approval on the info already stated. Your my hero JDM-EJ1
Old Apr 5, 2007 | 10:40 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (sol2hatch)
Congratulations you just shaved a breath-taking 15lbs.
Old Apr 5, 2007 | 10:52 PM
Mandark06's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Congratulations you just shaved a breath-taking 15lbs.</TD></TR></TABLE>
every bit counts = P
Old Apr 5, 2007 | 11:12 PM
amej8's Avatar
Default Re: (Mandark06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mandark06 &raquo;</TD></TR><TR><TD CLASS="quote">vacuum port??? o.O
the rest sounds easy enough thanks guys.</TD></TR></TABLE>
On the back of the intake manifold, there is a little nipple where a vacuum line hooks up. You'll see it when you're removing the entire unit and its parts.
Just cut some of the rubber hose that connects to it and close one end with electrical tape and slap the little "nub" back on.
Old Apr 5, 2007 | 11:18 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: (amej8)
dont forget there are 3 10mm hex bolts
na seriously 2 cables, a vacumn line and a plug
ps 15 pounds is alot seriously every 100 pounds ~.1 second on the 1320
Old Apr 6, 2007 | 07:20 AM
b0yg0tskills's Avatar
how can it get in your way when its only a button?
Old Apr 6, 2007 | 07:27 AM
* B A N N E D *
Default Re: (b0yg0tskills)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b0yg0tskills &raquo;</TD></TR><TR><TD CLASS="quote">how can it get in your way when its only a button?</TD></TR></TABLE>
gets in the way under the hood
Old Apr 6, 2007 | 11:32 AM
Mandark06's Avatar
Default Re: (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">
gets in the way under the hood </TD></TR></TABLE>
haha = P
thanks a lot guys = ) appreciate it.
Old Apr 6, 2007 | 11:45 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Make sure you take the cruise control switch out. That thing is heavy, i mean why keep the switch if your removeing the c.c j/k
Old Apr 6, 2007 | 11:52 AM
Mandark06's Avatar
Default Re: (phyzJunkieCivic)
= P good point. heavy like... 5 lbs? o.O i'll probably get around to that in a sec, i'm pulling the whole thing out now.
B16b-EJ8
Jul 7, 2006 08:25 AM
garyc17
Jan 27, 2006 07:25 PM
frampo
15
Dec 17, 2005 07:16 PM
TSL
Apr 13, 2005 10:34 PM
