1995 Honda Civic Dx
Hey we have a little problem with passenger headlight being dim when you turn the lights on .. ive seen alot of these problems on cavalier's but not on a civic does anyone know were i should start looking at ? maybe a faulty ground ? thanks alot and hope someone knows what to do !
Modified by projectpd at 12:52 PM 4/5/2007
Modified by projectpd at 12:53 PM 4/5/2007
yeah i cleaned the connector and nuttin seams to happen... we dont have a low beam but a very dim highbeam !! very odd problem .... il be changing the light switch tonight .. hopefully this will fix it !!! anymore ideals anyone ???
take your pefectly working driver side bulb and put in on the passenger side......is it still dim? if its not then you need a new passenger side bulb....if its still dim at least you dont have to waste your money on new bulbs bc thats not your problem.
Modified by rivaladore at 4:05 PM 4/5/2007
Yeah ... we tryed a new bulb same problem and connector is clean and is connecting right .. we did a voltage drop and were not getting anything so the connector is 100% functional ! now were thinking of changing the switch because we got a parts car so well try that out ! hopefully that will help or else well have to rewire it from the switch
I think it might jus be a short to ground. Ive seen the same problem before on a cavalier as well. The ground ended up being on the opposite side as the problem though. So the faulty ground is probably on the drivers side. Elctricity always takes the path of least resistance. Does your other light seem brighter than usual?
poms77
Honda Civic (2001 - 2005)
Dec 13, 2017 05:06 AM
Souldrinker
Honda Motorcycles
Nov 2, 2008 09:30 PM
