Running 15's wanting a Z-rated tire opinions
Old Apr 5, 2007 | 09:27 AM
94rs-turbo's Avatar
Default Running 15's wanting a Z-rated tire opinions
As stated running a 15x7 wheel and im wanting a Z-rated tire on the ground.
Ive used the Falken 615's and I dont like them, Kumho MX's seem to have a soft sidewall. Ive looked at the Fusion's doesn't look like a bad tire and since its Bridgestone's tire I know they have a stiff sidewall. Will be used mainly for street driven not daily though. Any thoughts?
Old Apr 5, 2007 | 10:18 AM
supersteven's Avatar
I checked the DTC website and found a couple ZR rated tires in 205/50/15. I'm not sure if that's the size you're running though. Anyway, here's some I found:
Hankook Ventus R-S2 Z212
Bridgestone Potenza S03
BFG G-Force T/A KDW NT
Cooper Zeon 2XS
Kumho Ecsta ASX
I'm sure there are a ton more. Hope this helps a bit.
Old Apr 5, 2007 | 11:52 AM
94rs-turbo's Avatar
"Hankook Ventus R-S2 Z212" lots of the miata guys I know use those and seem to have good luck with them
"Bridgestone Potenza S03" thought those were discountinuied?
"BFG G-Force T/A KDW NT" very noicy and overpriced IMO
"Cooper Zeon 2XS" those are POS
"Kumho Ecsta ASX"hate the tread on them and never really heard and good about them besides they are suppose to last because of the higher treadwear on them
Old Apr 7, 2007 | 08:15 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Running 15's wanting a Z-rated tire opinions (94rs-turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">As stated running a 15x7 wheel and im wanting a Z-rated tire on the ground.</TD></TR></TABLE>
Why do you want a Z rated tire, instead of one of the higher speed ratings like W or Y?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">Ive used the Falken 615's and I dont like them</TD></TR></TABLE>
What don't you like about them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">Kumho MX's seem to have a soft sidewall.</TD></TR></TABLE>
Not true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">Ive looked at the Fusion's doesn't look like a bad tire</TD></TR></TABLE>
You judge tires by looks?
Instead of making cryptic comments, why don't you tell us what you're looking for? Answer questions like the ones above, and the answers will help determine what tire might be best for your needs.
Old Apr 8, 2007 | 10:00 AM
94rs-turbo's Avatar
Default Re: Running 15's wanting a Z-rated tire opinions (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Why do you want a Z rated tire, instead of one of the higher speed ratings like W or Y?</TD></TR></TABLE>
Sorry meant all seriesof z-rated tires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">What don't you like about them?</TD></TR></TABLE>
Noisey(not a huge deal), they dont handle that great, I dont even have to turn that hard and they would break loose, Water traction isnt that great. They are OK but would like something better.
Working with the kumho MX's sidewall seems flimsy compaired to falkens, bridgestones, bfg's
I am just trying to use something different thats why I suggested bridgestone and the fusion aggressive tread hard sidewall and Ive used most tires out there
Old Apr 8, 2007 | 10:53 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">Sorry meant all seriesof z-rated tires</TD></TR></TABLE>
And why do you care about the speed ratings? Are you planning to go over 150 mph?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">Noisey(not a huge deal), they dont handle that great, I dont even have to turn that hard and they would break loose</TD></TR></TABLE>
On dry pavement, the Azenis handles and grips better than any other street tire. If that's not good enough for you, then you'll need to get race type tires, like drag radials. And they will wear extremely rapidly.
(If they're breaking loose easily, my bet is that the problem is not the tires, but the driver.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">I am just trying to use something different thats why I suggested bridgestone and the fusion aggressive tread hard sidewall and Ive used most tires out there </TD></TR></TABLE>
You didn't mention which Bridgestone tire you're talking about, but they don't make anything that grips better than the Azenis on dry pavement. Nothing they make in 15" sizes even comes close.
But go ahead, try other tires if you like. You'll figure that out for yourself soon enough.
Old Apr 8, 2007 | 11:27 AM
94rs-turbo's Avatar
And why do you care about the speed ratings? Are you planning to go over 150 mph?</TD></TR></TABLE>
No but v-rated tires ive used dont seem to grip as well as I would like, I mean I use v-rated tires on my daily and they isnt bad but for my other car I want something better
(If they're breaking loose easily, my bet is that the problem is not the tires, but the driver.)</TD></TR></TABLE>
Well actually I was thinking about getting RA1's ive know a couple guys who have used them on the street without any problems and last for awhile.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You didn't mention which Bridgestone tire you're talking about, but they don't make anything that grips better than the Azenis on dry pavement. Nothing they make in 15" sizes even comes close.
Thats why im asking for someone elses opinion
I dunno I'll prob just get cheap kumho mx's
Old Apr 8, 2007 | 12:34 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">No but v-rated tires ive used dont seem to grip as well as I would like, I mean I use v-rated tires on my daily and they isnt bad but for my other car I want something better</TD></TR></TABLE>
A higher speed rating has nothing to do with better grip and performance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">Well actually I was thinking about getting RA1's ive know a couple guys who have used them on the street without any problems and last for awhile.</TD></TR></TABLE>
I would not use R compound track tires like the RA-1 on the street, for many reasons. First, they wear rapidly (you might only get 5K miles to a set, maybe less). They are not very good in the rain (even though the RA-1 is better than most others in the rain, they're still not very good). And they need to warm up to be really effective, and you'll never get them heated up with street use. None of these things matter when using them on the track, and the RA-1 is a very good track tire. (I use them myself.) But I would not use them on the street.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">I dunno I'll prob just get cheap kumho mx's</TD></TR></TABLE>
Go ahead and try them. They're not as sticky as the Azenis on dry pavement, but they're slightly better in rain and they last a little longer too.
Old Apr 8, 2007 | 12:45 PM
94rs-turbo's Avatar
LOL I dont think they will last longer then 12k
Old Apr 9, 2007 | 01:15 PM
94rs-turbo's Avatar
nsxtasy why am i blocked from IMing you?
baiwldrnner
Honda Civic (2001 - 2005)
Nov 8, 2007 05:59 PM
TunerN00b
Oct 15, 2005 09:44 PM
93formula
15
May 5, 2005 04:53 PM
spock_rocker
33
Nov 3, 2004 10:53 AM
FifthGearOnline
25
Jan 27, 2002 10:49 PM
