Engine flooded with gasoline.... Why???
Old Apr 5, 2007 | 08:21 AM
EG_Type-R's Avatar
Default Engine flooded with gasoline.... Why???
I did an engine swap on my 95 EG CX, jdm b16a sir2... When I turn the ignition ON all 4 injectors start pumping gas into the engine and the engine gets flooded... I try changing the MAP sensor but still... I have no idea where to start checking... Any ideas guys???
Old Apr 5, 2007 | 01:16 PM
Perfectionist's Avatar
Default Re: Engine flooded with gasoline.... Why??? (EG_Type-R)
The ECU grounds the injector circuits to pulse them. Maybe you shorted them to ground or have them on the wrong pins on the ECU?
Old Apr 5, 2007 | 02:16 PM
EG_Type-R's Avatar
Default Re: Engine flooded with gasoline.... Why??? (Perfectionist)
I think I shorted them to ground, what can I do to fix this???
Old Apr 5, 2007 | 05:36 PM
arc_55's Avatar
check all wiring from the P2 injector plug to the ecu. The computer controls injector pluse width on the ground side to the ecu. The reason this is done is because of voltage spikes and also if there was ever a short to ground before the injector the injector would be inoperative and throw a code. Unfortunely it sounds like you have a short to ground on the controlled side. I would check your ground side of the injector plug first.
Old May 19, 2008 | 11:07 PM
riddlinkid1986's Avatar
Default Re: (arc_55)
bump! same issue! how to fix it yo!
Old Mar 8, 2009 | 11:45 AM
alacard's Avatar
I realize this is an old post. But it never had a resolution. So for those of you searching...this problem (for me at least) was caused by a fried ecu. I switched out the ecu and it fixed the problem. I am, however, still dealing with the effects of a flooded engine.
Old Jan 24, 2011 | 07:35 PM
buckner2009's Avatar
ya bumb have a 97 dx switched ecu switched cold start map engine harness' its spitting sputterering at idle rev it up fine but rich as hell! done cam sensor coil every normal thing think off cleaned injectors everything stumped dd! need it running (normal)
carlos8
Dec 19, 2016 07:11 PM
B_Swapped93
Apr 24, 2013 08:44 PM
fasteddief23
Jul 6, 2011 01:31 PM
HondacivDX
Sep 10, 2010 04:12 PM
BfromSD
Jan 24, 2008 05:50 PM
