Ignition timing
Old Apr 5, 2007 | 07:44 AM
ABK's Avatar
ABK
Default Ignition timing
How much should I back off the ignition timing while tunning (with crome) a 12.5:1 itr motor? It's running 93 octane and ctr cams. First couple tunning pulls in vtec we got the air fuel ratio down to low 13s high 12s but then when you let off the gas it back fires and throws a check engine light (didn't pull the code because we just reset it, will check next time). I got a feeling that knock sensor is acting up a little, plus the o2 does not seem to respond at all. We know that o2 fucked and need to be replaced. Any tips? Please no flaming...
Old Apr 5, 2007 | 09:14 PM
mtber's Avatar
Default Re: Ignition timing (ABK)
Listen carefully
Get your car on a dyno
Old Apr 8, 2007 | 06:48 AM
ABK's Avatar
ABK
Default Re: Ignition timing (mtber)
okay I know that. We need to base map it first make sure that it doesn't have any missfires and hold compression and all that. Still need to break the motor in all the way before it goes on the dyno. I was just wondering what's safe on a 12.5:1 comperession motor with 93 octane
Old Apr 8, 2007 | 08:19 PM
ABK's Avatar
ABK
or better yet can somebody give me their crome map bin.
Old Apr 8, 2007 | 08:37 PM
salman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">or better yet can somebody give me their crome map bin.</TD></TR></TABLE>
From my experience they wont,,..
Speedra500
Apr 4, 2005 02:48 PM
WAFFLES
Jul 3, 2003 04:17 PM
M SPEC
Jan 14, 2003 12:08 PM
ActiveAero
Sep 3, 2002 10:33 AM
HX_Guy
Nov 2, 2001 11:38 AM
