Did my clutch go out !?
Old Apr 5, 2007 | 05:14 AM
roboda's Avatar
Default Did my clutch go out !?
My mom asked me to move my 99 gsr so she could get around me. So I start up my car, there pretty much no clutch pressure. Then I attempt to put it in reverse, but it wont go in. Then I tried to push it really hard into first, but it never went in. I noticed when i tried this my rpms went down. Whats the deal ? I cant drive my car !!!
Old Apr 5, 2007 | 06:13 AM
SL0-hatch's Avatar
Default Re: Did my clutch go out !? (roboda)
did you check the clutch cylinder to see if there is any fluid in it. also check the slave cylinder to see if it needs to be replaced.
Old Apr 5, 2007 | 08:34 AM
mike5809's Avatar
Default Re: Did my clutch go out !? (98IntegraGSRguy)
What was said above.
Check the fluid, most likely it is empty or close to. Fill it with brake fluid and keep an eye on it to see if it leaks, it may take a day or so to get back to normal if air got in the line or you may need to bleed to line. If it does leak it is prolly slave cylinder or master cylinder.
Old Apr 5, 2007 | 12:42 PM
98GSRDC2's Avatar
try a flush
Civic Racer X 7
11
Aug 27, 2014 05:53 PM
S2Integra
Transmission & Drivetrain
Oct 18, 2011 08:28 AM
eg6sittingon57cs
Aug 8, 2007 10:44 AM
GraphiteMW
Mar 25, 2007 09:26 AM
malubawla
Oct 16, 2005 04:16 PM
