My 95 civic swap PLEZ HELP
Old Apr 4, 2007 | 10:15 PM
lukerc45's Avatar
Default My 95 civic swap PLEZ HELP
ok i have a 95 ex civic coupe and i want to do a motor swap and was wondering what is the best to swap in the car i have 10k to spend and was thinking of a B18c1 or a H22. was wondering what would be the best and easyest for my to swap in and most cost effisent. i also was wondering about having to rebuy my intake since it would be a new motor and headers.
Prices and miles (i am getting this from a honda recking yard)
H22 37k miles and 3,600 complet swap
B18c1 78k miles 2,800 complet swap (needs new cluch)
Old Apr 4, 2007 | 10:57 PM
Turbo(less)DB8's Avatar
Default Re: My 95 civic swap PLEZ HELP (lukerc45)
prob the best swap for your car would be the b18. The swap drops right in with teg motor mounts and integra axles can be used. Knock and IAB need to be wired however. The H22 requires custom mounts (like hasport) AND custom axles. Usually, H22's in ej1's cause poor handling as there is much more weight in the front. What intake do you have? If you have an after market HEADER for your d series engine, it will not work on either b or h setup. Hope this helps.
Old Apr 5, 2007 | 12:55 AM
TypeRasta's Avatar
Alright if you have 10k get the B18C R. The Type R motor. 210hp@8000/134 lb-ft@7500
or you could always go K series...
Old Apr 5, 2007 | 01:22 AM
vonrobins1's Avatar
you have 10k and your asking about what swap should you do (slap) b-series boosted or k-series
Old Apr 5, 2007 | 01:31 PM
TypeRasta's Avatar
no joke. if i had 10k to spend on my car i would be at the shop right now.
Old Apr 5, 2007 | 01:36 PM
eg8tuner's Avatar
if you go b you are gonna need the shift linkage too
but a boosted B would be a great swap and easier to do than the H
Old Apr 5, 2007 | 02:34 PM
h22xcivic's Avatar
first off, search for the answer!!! this question has been asked at least 200 times!!!
too answer your question....Boosted B18C1!!! FTW!!!
Exvtec king
15
Jul 10, 2007 08:45 AM
Monchi
10
Feb 22, 2006 08:11 PM
Adams5
Feb 4, 2004 05:15 AM
si foo
Jun 27, 2003 03:15 PM
