Dash Ligh/Rear Lights went out
Old Apr 4, 2007 | 08:17 PM
JohnD1079's Avatar
Default Dash Ligh/Rear Lights went out
hey, i have a 92 LX, and my dash lights and rear lights are out. like when you turn your headlights on the dash and the rear lights go on, well mine done anymore, i was driving and they just went out. i searched and i found this https://honda-tech.com/zerothread?id=1891295. i checked all my fuses and "small light" was out so i changed it, but it still didnt do anything. the only ones i didnt check where the relays on the fuse box under the hood. i checked all the fuses in the drivers side and under the hood. also someone in the post above said that there are 3 fusebox's one on each side and under the hood (for a 98). is that true for 92's bc i looked and i didnt find one on the passenger side. i will be changing the relays under the hood 2morrow, hoping it fixes the problem, if it doesnt, what do you guys recommend?
Old Apr 5, 2007 | 04:21 PM
JohnD1079's Avatar
Default Re: Dash Ligh/Rear Lights went out (JohnD1079)
Can anyone help me out on this, bc i am stumped. I also changed the turning signal relay right about the driverside fusebox. i read about it somewhere 2day and still nothing. i really need to get this fixed BC i drive around at night a lot, and the rears dont work.
Old Apr 5, 2007 | 04:25 PM
lowered94accord's Avatar
Did you make sure you put the right fuse in when you replaced the small light fuse..and did you make sure it didnt blow again?...check that to make sure you never know
Old Apr 5, 2007 | 07:22 PM
JohnD1079's Avatar
Default Re: Dash Ligh/Rear Lights went out (lowered94accord)
yes i checked the small light fuse to make sure it didint blow again. it was fine. the only thingi was thinking is if there was something the the turn signal switch that was broken, bc usualy when i turn the daylights on the dashlights go on, the gloe compartment, the rear lights and the ting, ting when you open the door with the lights on goes on but down nothing goes on. so pretty much there are 2 levels when you turn the lights on. everything from the first level is off. im thinking there is something wrong with the first level in the light switch. do i have to change the whole light swich?
Modified by JohnD1079 at 9:05 PM 4/5/2007
2hondas_noluck
Dec 25, 2008 07:46 AM
wsuozzie
Nov 15, 2006 07:06 AM
napalm_srv
Oct 2, 2005 04:11 PM
Tee Jay
Feb 23, 2004 04:59 PM
